02 yzf426 header red hot?
21 replies to this topic
  • Ross chan
Posted October 25, 2007 - 11:08 AM
Bike runs fine, I let it idle for about one min and the exhust header from the cylinder is glowing hot, might it be to rich or lean, how could I fix this problem any help would be great thanks a million.
  • crf250rileyracer
Posted October 25, 2007 - 11:15 AM
the exhaust is supposed to do that and is normal, it just means it is very hot
  • Racer808
Posted October 25, 2007 - 11:16 AM
Oh boy, you are gonna chewed out for posting this. Been answered a million times. It is totally normal for the header to glow, when you are not moving the header doesnt have a chance to cool. Freaked me out the first time my 426 started doing it in my garage one evening when I was working on it. But its normal, now go ride it!!!
  • jeffgg
Posted October 25, 2007 - 11:23 AM
:crazy: Warning...sarcastic reply.:D
Three things come immediately to mind after reading your post:
1) Search the forum and you will find that this is a common occurance when you let a 4st idle. You are the latest of a never ending string of people who have asked this question.
2) The bike is a few years old. My quess is that it otherwise runs fine, so this is not a problem; as long as you don't let it idle for more that a few minutes. Water cooled 4st's don't like to idle for prolonged periods.
3) Like the old joke; Patient - "Doctor, my arm hurts when I do this!" Doctor- "Don't do that!".
Bikes are ment to be ridden, not looked at while idling (I'll bet it was indoor too).
  • WB450
Posted October 25, 2007 - 02:26 PM
I was caught off guard when my 07 did the same thing, but I was lucky enough to see a thread about it so I didn't have to get the ass chewing that usually comes with this question
  • BRP-rider
Posted October 25, 2007 - 02:30 PM
I have a 2000 426 and if you let it sit and idle the header does not become glowing hot. If your bike sits and idles and the header becomes almost red hot, you are running to lean or your ignition timing is advanced too much.
  • WB450
Posted October 25, 2007 - 02:39 PM
Get a titanium head pipe and see if it gets hot.
Posted October 25, 2007 - 04:07 PM
Ignition timing is not adjustable, in the first place, and in the second, exhaust heat is elevated by retarded timing, not the other way 'round. If someone has disconnected the neutral switch on your '00, and/or replaced the header with a stainless one, it will be less prone to it than it was when stock. It should be noted that under normal circumstances, the header will glow in about 90 seconds of idle time, but may not be seen as glowing unless you are in a lower light situation, like twilight, or your driveway at night.
It's only abnormal if it glows red in full sunlight, in which case, it will probably exhibit some other symptoms of being too lean (say, from a stuck hot start, running very poorly) along with.
  • 642MX
Posted October 25, 2007 - 05:22 PM
Lets see a picture of the abnormally hot pipe....:crazy:
Posted October 25, 2007 - 06:46 PM
Well, let's see, there's this one:
  • 642MX
Posted October 25, 2007 - 07:12 PM
Yep. Thats a good example of a pipe thats too hot. :crazy:
  • jayh300
Posted October 26, 2007 - 05:52 AM
that picture makes me laugh hard every time..... get the dogs and marshmellows ready !!!!!
  • King_Air
Posted October 26, 2007 - 07:51 AM
I blame global warming for my glowing header.
  • Ga450owner
Posted October 26, 2007 - 08:54 AM
and I keep thinking that Glowing headers cause Global warming........:crazy:
  • Racer808
Posted October 26, 2007 - 10:11 AM
I used to worry about my dogs glowing red header, then my mother explained it to me, what a relief
  • rdefonce
Posted October 26, 2007 - 01:06 PM
Lots of good humor in this thread, wa wa wa.:-)))
Actually I noticed that my old reliable '99 YZ's header glowed less after I jetting it richer (richer pilot, fuel screw setting) since it was so lean stock.
Also bigger main jet (180) and one clip richer on needle really helped it run better at my low altitude (500 ft) but that would not affect the "glowing" any.
  • sirthumpalot
Posted October 26, 2007 - 04:22 PM
Every time I see that picture it cracks me up! Especially the LP tank front bumper!
  • 00YZ426FMRCD
Posted October 26, 2007 - 07:54 PM
Glad I read this post. I thought there was something wrong with my 426...
:worthy: - RCD
  • MichiganMXer
Posted October 28, 2007 - 04:43 PM
Dude I've got an 01 that runs like the day I bought her off the showroom floor and the header has turned red since that day. Your response could get people tearing up their bikes when its perfectly normal for the head pipe to get hot.
  • scalejockey
Posted October 29, 2007 - 07:05 PM
They do get hot.. but how fast is it getting to this red stage 2 minutes from cold or 6 minutes? I worked on 450 with a carb that had it's slide plate put in up side down. (The flat side goes down) but the result was it would get hot real fast. ..and run a little crappy.
  • 0 replies
  • Hot  50 replies
  • On January 15, 2017
