test rode a WR400 today: why no bottom end?
11 replies to this topic
  • Krannie McKranface
Posted October 23, 2007 - 05:23 PM
I am looking for a plated ............ (fill in the blank) for local rides, and today I tried out a '99 WR400. It had been uncorked, fmf bomb/Q2, and a fresh valve train.
I was suprised to find that while it runs very clean down low, It had a hard time pulling in the low and mid range: it really needed to rev out to pull each gear. And it was geared very low (55mph tops).
I suspect a worn piston/rings, as it had no decelleration resistance when the throttle was backed off (unlike my Honda CRF).
Is this basically the nature of the 400: a bit revy, and about 36 hp? That's what it felt like (compared to my uncorked DRZ 400).
I'm asking because I like the way the WR's handle the really tight trails, and there are several plated ones around here to look at.
  • JSanfilippo
Posted October 23, 2007 - 10:08 PM
I rode a choked up YZ 400f (pro circuit T-4 with restrictive baffle) this saturday and it had decent low end. Me thinks that bike you test rode may have had a problem
  • Mutu
Posted October 24, 2007 - 12:35 AM
Bike sounds wrong mate, WR400's are animals.
  • husqvarnarider
Posted October 24, 2007 - 02:12 AM
Agreed, my 99 wr400 is super strong on the bottom. It also has a TON of compression braking. I have no problem running with the newer 450's. I'd say it's probably due for a top-end.
  • matt4x4
Posted October 24, 2007 - 04:06 AM
Mine pulls strong right through the revs, definitely something wrong.
Were oyu able to kick it without using the decomp. lever to get you past TDC for the kick - I'd expect that to be a sign of lower than normal compression.
  • SJMC_DON
Posted October 24, 2007 - 07:56 AM
I agree with every one else, my 99 was a rude and nasty beast compared to any of my other WR's :crazy: It hit hard, like YZ hard :D
  • JSanfilippo
Posted October 24, 2007 - 09:35 AM
Tell him to lower the price by $500, then spend like $220 on a piston, rings, base and head gaskets, and a timing chain :D
I'm sure you can do it yourself! :crazy:
  • 07thommi
Posted October 24, 2007 - 09:40 AM
It must have been that bike, maybe a top end is needed?
My dad's WR426 is an animal. It is a little heavy but it definatly is no slouch. It flat gets up and goes!
Ride a different WR400 and feel the difference!
  • dmoney1074
Posted October 24, 2007 - 09:43 AM
It felt like a drz???? Oh ya, something IS WRONG!!!
  • byggd
Posted October 24, 2007 - 12:49 PM
Might me a dumb question but what size sprockets? :crazy: If it has a 15 front and 48 rear the low end might be lagging
  • Birdy426
Posted October 24, 2007 - 02:09 PM
Krannie-
Definately something wrong with that bike...like you suspect, probably top end. Was it hard to start? Could you kick it through wihtout the decomp lever? If the valve train had been gone through, it's possible that the intake cam is timed wrong, as well. Will the owner let you run a compression check? My 444 puts out about 185 psi. I would expect a 400 in good shape will be somewhere between 165 and 180 psi as well. If the compresion is good, offer the guy a bit less, and work the issue. Maybe cam timing, maybe ignition. As you know, the plate is worth a bunch and you will love the bike once you get the low end worked out. I'm in Palmton and have a 426...available for parts swapping shotgun troubleshooting if you pick the sucker up.
  • eklock
Posted October 27, 2007 - 09:02 PM
I recently bought a '99 400F and can attest to the power they make. Scary sometimes because I'm a novice rider. My co-riders are on 426's, 450's and 250 2-strokes, I have the oldest bike in the bunch but hang with them easily.
The WR/YZ400 is the benchmark for all bikes since it's introduction. If your bike performs the way you say it does, something is wrong for sure. The only problem with the 400 IMHO is it's weight, the newer bikes are lighter especially the KTM's but I can't afford them.
