06 YZ450F Foot Rest Bolt
13 replies to this topic
  • akonibai
Posted October 23, 2007 - 10:22 AM
what's the size of this bolt? and is this called torx? the encircled one!!
Posted October 23, 2007 - 10:39 AM
Yes, it's a Torx fastener. Do you mean to ask what wrench size to use?
  • akonibai
Posted October 23, 2007 - 12:37 PM
yes because i need to buy a tool to remove it.
  • twenty34
Posted October 23, 2007 - 12:40 PM
I tried using a Torx tool to remove it, but ended up breaking the bit. It's on there!...You may need to heat it as the Torx socket isn't strong enough to get it off.
  • akonibai
Posted October 23, 2007 - 12:49 PM
what size did you use?
  • Mike546
Posted October 23, 2007 - 01:37 PM
T-50 or T-55, buy a good quality bit so you don't strip it. If it won't come out you can start it with a chisel.
  • WB450
Posted October 23, 2007 - 02:00 PM
Your also going to need a impact driver!
  • akonibai
Posted October 23, 2007 - 03:04 PM
hehehe, i'll buy craftsman tool and use an impact tool to remove it.
  • Mike546
Posted October 23, 2007 - 03:10 PM
Now I remember, I couldn't find my impact driver and that's why I had to use the chisel.
  • altered
Posted October 23, 2007 - 03:11 PM
Put the torx bit in the bolt and smack it with a dead blow hammer to loosen the Loctite. Those suckers weren't put in to come out easy.
Posted October 23, 2007 - 04:07 PM
It's a number 50. Use a little heat, and an impact, if you can get one. It won't come out easily.
  • Smokeslider
Posted October 23, 2007 - 06:16 PM
you might also try going to a auto parts store (I went to Schucks) and buy the kit that breaks stripped screws loose. You just put in the bit you need(it comes with a few) and pop it with a hammer. Works great for anything that is stripped out. I can go look in my garage for more info on it if you need.
  • todds924
Posted October 23, 2007 - 06:23 PM
Snap-On T-50, Lots of heat and a good Impact.
  • akonibai
Posted October 23, 2007 - 06:42 PM
thank you guys.. that really helps a lot.
  • Hot  38 replies
  • 0 replies
  • Hot  47 replies
  • On January 15, 2017
  • Hot  113 replies
