your opinion please
7 replies to this topic
  • Motosprtman
Posted October 22, 2007 - 10:11 AM
gotta a spare set of sprockets for the 650L 14 /48 and a DID O ring chain, thinking of installing on the 86 XL600 -
whatcha think? and what would be the result, stock is 13 / 51
  • martinfan30
Posted October 22, 2007 - 10:30 AM
they say changing 1 tooth in front is like changing three out back.
soooo, you are going from low, low, to semi low(lol). I RUN 14/48 on my 05 650L and it is great on the hiway and a little better offroad.
your choice would be good if doing more hiway on your 600.
  • Motosprtman
Posted October 22, 2007 - 10:34 AM
well the OEM sprockets look pretty good on the 600 but the chain is limp .... pretty sure it is OEM with 14K on it.
  • martinfan30
Posted October 22, 2007 - 11:42 AM
sounds like it is stretched maybe?
  • absynth01
Posted October 22, 2007 - 12:31 PM
I wouldn't use a chain with 14,000 on it. Two months ago, I lost my chain on my R, at 70. The chain was somewhat stretched. The chain slider on the swingarm became loose and got caught up in the chain because of the chain slapping it. I got lucky and the chain didn't get caught up front or in the rear to bad!!! I got a new non Oring chain for 20 bucks, front sprocket for 14 and had a rear. I don't know why the chain was so cheap, but was what a few racers around here use.
  • martinfan30
Posted October 22, 2007 - 12:48 PM
is that the only advantage? cost?
  • Denn10
Posted October 22, 2007 - 01:00 PM
i wouldnt go with that gearing if stock is 13/51 it will be way to high with the 14/48 and you would only want to use it for cruising.
  • absynth01
Posted October 22, 2007 - 03:08 PM
After talking to a few peeps O-ring chains are less efficient than non-oring. There is more resistance on an oring chain. I thought now we are splitting hairs here. I would never notice the difference, and I can't. The one BIG advantage to an oring is it requires less lubeing and maintenance. Needless to say when it was 20$ for a new one, I bought two. Besides, my machines always get looked over/fixed and washed before going back in the garage so one is ready to go with a phone call!!!!!!
This chain thing kinda follows the same theory as the chain,belt,shaft drive arguement. Chain is most efficeient(less resistance), then I think shaft, then belt.
Honda XR650L 2016
  • 0 reviews
  • 2 replies
  • Hot  35 replies
  • Hot  60 replies
Honda XR650L 2017
  • 0 reviews
