z-start on wr400 y2k
4 replies to this topic
  • wild west al
Posted October 21, 2007 - 02:25 AM
Has anyone else here fitted a z-start to a wr400f is so did you need to install any of the shims between the inner basket and pressure plate .My instructions say nothing about adding shims although I got 80 in the packet with the locating studs for installation ???:D I have looked on the rekluse web site and there is no mention in the installation manual online however they are required in the 450 and 426 models :crazy:
  • ncampion
Posted October 21, 2007 - 07:31 AM
Installed a Rekluse on my 98' WR400 a couple of years ago and don't recall any shims needed. I know they changed the clutch a bit between the 400 and 426. I didn't need any help, but I understand that the people at Rekluse have been very helpful. Might be a little harder to call for AU. You'll love it once you get it set up.
  • DanyR1
Posted October 21, 2007 - 09:41 AM
Check your clutch plate you have one not the same size of the other one you have to finish whit this one (the last one) I have do the same mistake.....good luck
  • SXP
Posted October 21, 2007 - 05:24 PM
No shims supplied in my 400 kit, only steel plates of different thickness to adjust the "installed" gap.
  • wild west al
Posted October 21, 2007 - 07:21 PM
Thanks folks ,I had suspected they were just thrown in as a standard hardware kit but always like to check .AND yes I am sure I will love the z-clutch as we do a fair bit of hill climbing and Iam not as quick with the left fingers as i used to be so hopefully I wont be kick starting it as often due to stalling .I have already done the feeler guage set up and only needed 1 of the rekluse plates as the outer steel to get back into tolerance
