Would you guys do this trade?
15 replies to this topic
  • mbogosia
Posted October 20, 2007 - 03:54 PM
I have a nice condition stock 2001 KX250. Bike looks good and runs good. Everything is stock and it could use a new piston and ring this winter just to be safe. Here is the bike I would be trading for: http://lexington.cra.../449115075.html
We each have to drive a good 1 1/2hrs to do this so do you guys think its worth it?
  • mbogosia
Posted October 20, 2007 - 03:56 PM
Here is a better picture. http://i173.photobuc...din/Bike060.jpg
  • 917 rider
Posted October 20, 2007 - 05:01 PM
why does he want to trade, what year is the yami.the yz is
alot better bike.depends on what kind of shape its in though i would have to check it out pretty good. 2 stroke rebuild-300,4 storke-3000
  • todds924
Posted October 20, 2007 - 05:09 PM
4-stroke 1000.00....Thats with a new crank. Where do you get 3000 ? A 2 stroke rebuild could be much more than 300.00. depends on what were rebuildin!
  • fatchellparty
Posted October 20, 2007 - 05:16 PM
every time i see a pic of a 426 i get a little sad:(.....i could of had one last year, it was so nice but my dad made me get the 230...hopefully next year another one will come up for sale.
  • mbogosia
Posted October 20, 2007 - 08:44 PM
He says that he has been on 4 strokes since 2001 and misses the 2 strokes. I am skeptical because if this thing needs a rebuild I am screwed. I could probably do it myself, but it would be a very hard project for me.
Here is an email on the bikes background:
"Okay, I bought this bike from my ex bro-in-law in January because he had bought an 03' CRF450. He is the original owner and appears to have maintained the bike well. He changed the oil and filter every 5 hours and cleaned the air filter after every ride, as do I. Neither of us have ever raced the bike, strictly woods and trails only.
As far as the working order of the bike it is pretty well perfect. I just installed a new top end in it less than 10 hours of ride time ago with a Wiseco High Comp piston/ring kit. This High Comp gives the bike even more low-end torque. I also installed the 450 auto-decompression cam so you don't have to use the decompression lever to start it anymore. 426's are notorious for their starting drill that everyone hates. Doing this mod eliminates the need for this. I checked the valves when I got the bike and they were in spec and then they had to be adjusted due to the new cam being installed. No stripped drain bolts, broke levers, etc... I also installed a Dubach Racing Hot Start System ($90) which puts the hot start on the throttle side instead of having to reach down to the card to pull the hot start out. I also replaced the fork seals and oil when I got the bike because the right one was leaking a little. Overall the bike is in good shape running wise and appearance wise. I put some white backgrounds on the side number plates and didn't do so well with then. One side has a little cress in it.
I have the stock gearing on it now and I also have a 13t front for the tighter woods. This bike is a beast on power, but like you said... it is a bit heavier than the 2t's. I think it is about 15lbs heavier, but it really doesn't feel that heavy to me. I had a WR before and it weighed a TON."
  • 917 rider
Posted October 21, 2007 - 02:26 AM
im sorry i was thinking about my honda 450 crank-piston-valves-cylinder head redone-valves-some more valves-and did i say valves and cylinder:foul: :crazy: .ive had plenty of two strokes and they hardly go over 300. i did do the work myself on 2-strokes but the 4-stroke is to much work for me.The bike sounds great with all the right mods,i would have to take that drive its worth it just to see.Make sure he lets you ride it and look over it really good:naughty: if it all looks good you wont be happier:ride:
  • mbogosia
Posted October 21, 2007 - 04:51 AM
I just think the bike obviously has some flaws if he wants to go back to a 250 2 stroke. Too heavy maybe? Not a very good powerband maybe?
  • walent215
Posted October 21, 2007 - 04:58 AM
i would say the weight issue is swaying him back to the 2s.
  • creeker
Posted October 21, 2007 - 05:15 AM
That's a good looking 426 he has there... :crazy:
  • mbogosia
Posted October 21, 2007 - 06:16 AM
Timing chain has also been replaced. Hmmm, I just can't decide about the weight issue. Heck, my 250 is heavy when I get stuck on a hill. When riding it feels pretty light though.
  • mxer36
Posted October 21, 2007 - 06:21 AM
yes i think you should do the trade thats a sweet bike
  • THEDUSTCLOUD
Posted October 21, 2007 - 07:32 PM
That's a good looking 426 he has there... :bonk:
hahahaha... :crazy: :D :applause:
OWNAGE POLICE!!!
  • 00YZ426FMRCD
Posted October 22, 2007 - 07:54 AM
I suggest you guys meet, switch bikes and ride some trail & MX. You need to ride and start the 426 before you trade & check it out. The 426 may or may not be rideable for you depending on your physical size, ability and whether you have plans for MX or trail riding - or both. Going by the pictures and what has been done to it, it appears to be in good shape. You might ask if the key has been replaced on the crank.
- RCD
  • yamaha racing 230
Posted October 22, 2007 - 01:17 PM
yea i say ride it and make ure decion but i think that is a alsome trade and if i were u i would do it that 426 should be ure 250 in a drag race
  • mbogosia
Posted October 22, 2007 - 02:59 PM
Well the big trade is off. We both just decided it is not worth it. I am loving my 250 and really jsut getting used to it. I ride a lot of tight trails and when I read about the 426 I see a lot of complaints about handling in tight trails. Thanks for your help guys.
  • Hot  50 replies
  • 5 replies
  • On January 15, 2017
  • Hot  113 replies
