How long do you let your air filter oil dry???
24 replies to this topic
  • skatpex99
Posted October 20, 2007 - 12:12 PM
I just got a twinair air filter and on the bag that it came with it says that I should let it dry for 12-24 hours. The air filter oil that I use says that it only needs to dry for 15 minutes. I am going riding tomorrow and I need to change my oil tonight so can I just let the air filter dry for a couple of hours and it will be fine? thanks.
  • mc250f
Posted October 20, 2007 - 12:15 PM
i would think so man. i would try a dehumidifier to get that moisture out. even if u let it dry for a few hours, then it sits in the air box till tomorrow, i don't see it being a problem.
  • KX125TwoStroke
Posted October 20, 2007 - 12:18 PM
yea it will be alright man. Just let it sit for a couple hours, and then oil-r-up and put her in the air box and she'll b all nice n ready to go tmrw
  • KYMXRacer
Posted October 20, 2007 - 12:40 PM
I always used a hair dryer for mine. It'll be dry in about 5 minutes.
  • Kent Rathgeber
Posted October 20, 2007 - 12:48 PM
I don't know for sure how long it takes, but I always let my filters dry overnight before I re-oil them (that's why I have 2 filters) . I don't like the idea of trying to oil a damp filter because the oil will not stick to the fabric properly.
  • CORider63
Posted October 20, 2007 - 12:51 PM
Ditto on the 2nd air filter.
I keep one clean and oiled filter in a gallon-size ziploc bag. :crazy:
  • skatpex99
Posted October 20, 2007 - 01:05 PM
It is a brand new filter and I have never got it wet.
  • mikem
Posted October 20, 2007 - 01:07 PM
I have a buddy who is a top dirt bike mechanic. He says there is no need to let it dry out. He says after washing, simply hit it across your hand a few times to knock a good bit of the water out. You may even squeeze it gently with a paper towell after hitting it on your and a few times. Then oil and go. He says the water won't really hurt anything, but too much filter oil will. It's the way I do it all the time now. Sometimes sputters just a bit, but then burns off.
  • joshb
Posted October 20, 2007 - 01:08 PM
just oil it then and your good to go.
i always throw mine in the dyer on medium though to get miine dry.
  • Kent Rathgeber
Posted October 20, 2007 - 01:14 PM
Ok, I misunderstood. I thought you were talking about after cleaning the filter.
I usually oil my filters at least 24 hours before I use them, and then put them in a Ziploc bag that has holes punched in it. This gives the oil carriers time to evaporate.
Just for the heck of it, one day I oiled my air filter, put it on my bike, and tried to start it. NO WAY would that bike start, it wasn't getting enough air. The reason is that the carrier in the filter oil hadn't evaporated yet, which basically plugs up the filter so no air will pass through.
  • firsthumper
Posted October 21, 2007 - 09:31 AM
You should always dry the filter after washing it. I just got a Twin Air filter, and that's what the instructions say. It traps moisture otherwise and couldaffect the proper functionning. You can finish drying it with a blowdryer but I 'd be careful, too much heat is probbaly bad for the glue and the foam.
Then it's best to let the oil dry 24 hours or so before riding, although it's no big deal if you wait a little less. Just make sure there isn't too much oil.
  • 06yz
Posted October 21, 2007 - 10:04 AM
I always make sure my filters are completly dry before oiling them. When I oil the filter I put right on the bike. I've never had any problems doing this.
MAX!!!
  • boomman
Posted October 21, 2007 - 11:03 AM
I use gas to clean mine and 2 minutes in the sun, prest-o, it's dry.
  • CamP
Posted October 21, 2007 - 12:39 PM
If all you are using is a solvent to clean your filter, you really aren't cleaning your filter. After using the solvent, you should follow up with a couple dish soap and water washes in a bucket. This can take three or more soap and water washes before silt stops coming out of the filter, then follow up with a pure water bath/rinse. You will be amazed at how much dirt continues to come out of the filter. It will look like a handful.
  • steve_97060
Posted October 21, 2007 - 01:20 PM
I was just going to say the same thing... it is amazing how much more dirt, and filter oil, continues to come out of the filter with a dish soap and warm water cleaning after doing the initial solvent/gas cleaning...
  • NorCal
Posted October 21, 2007 - 02:11 PM
I just throw mine in the dryer (when my roommates aren't looking) for ten minutes after I clean mine.
Does gas and hot soapy water work well for cleaning air filters? I have been using that UNI filter cleaning. While it works well, it is a little pricey.
  • CamP
Posted October 21, 2007 - 03:06 PM
I prefer kerosene over gas. Gas will expand the pores of the filter, is harder on the glue and is more toxic. Both Twin Air and Honda recommend kerosene also. In fact, Twin Air filter cleaner is actually kerosene.
  • reed1
Posted October 21, 2007 - 04:49 PM
Hope to God the bike doesnt back fire:eek:
  • m22
Posted October 21, 2007 - 04:52 PM
After i clean a filter i give it 24 hrs to dry before oiling. After oiling i also try to give it 24 hrs. As others have stated have at least 2 filters so you always have 1 ready.
Twin air filter, oil, & cleaner
Mike :crazy: :D
  • Denn10
Posted October 22, 2007 - 05:59 AM
Hes NOT talking about after cleaning hes asking "how long to let the OIL dry" UHHH i dont let mine dry really sometimes i clean and re oil and im riding same day. Ive started my bike MANY MANY times right after a fresh filter and oil go on and it ALWAYS starts, i dont know why that one guy said he couldnt get a bike to start after he put a filter in. You dont need to over oil a filter just get a good coating and get it even throughout the filter and take it out, if you plan a little clean and oil the night before if you really want to.
Rmz 250 enduro conversion by SD513
Dirt Bike   Make / Model Specific   Suzuki   RM-Z 250
cr125 build questions by austin_honda
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • 7 replies
Beta VS KTM handling by abj1
Dirt Bike   Make / Model Specific   Beta
  • Hot  37 replies
2002 yz250 Revive with WR Transmission Guide (pic heavy) by blbiker56
  • Hot  36 replies
2015 wr450 engine knock. Video inside. by cdf450
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  58 replies
