Electric Output Stator for 06-07 YZ450F - UPDATE
98 replies to this topic
  • swatdoc
Posted October 19, 2007 - 11:43 PM
There has been quite a few people asking about a stator for the newer 450's (06 and up) that would allow them to run a headlight/taillight. I was one of those people for quite a while.
As some of you know, after EXTENSIVE research, the choice boiled down to only 2 options. One was having your stock stator rewound by Lake & Trail, the other was an aftermarket unit by Electrosport. Both units are rated at 50 watts AC output.
Many people don't think too highly of Electrosport's products. In fact, the unit I got had the backing plate machined incorrectly and would not fit the ignition cover. I had to cut off all the electrics from my stock backing plate, cut everything off the Electrosport unit, and then solder the Electrosport electrics to my stock backing plate. Frankly I'm amazed it works after that. To their credit, Electrosport knew about the problem, the error was from the company in Asia that makes the unit. I told them I'd take it anyway as it was the only option I knew of at the time. I had called Electrosport last week and asked them if they ever fixed the problem and had gotten any more units in, and they said they had not. So I guess I might have gotten the only one from them.
Well, today I was at the local MC shop picking up some more stuff, and I happened to look at a new 08 MOOSE catalog they just got in. To my surprize, they listed an electric output stator for the 06-07 450's !!! :crazy:
Same 50 watt output, so you'll still have to watch your choice of components, but I think I'll feel a little more confident in the Moose product's reliability. I ordered one today - if nothing else, so I have a backup. Retail is right around $200. Moose part number is: 2112-0228
  • akonibai
Posted October 20, 2007 - 05:25 AM
have you check trailtech. the site mention the output is 100w.
Electrical System Kit: Yamaha YFZ450 All Years, WR450 '03-08, WR250 '03-08
$199.95
S-8500
Stator for Yamaha YFZ450 All Years and WR250/WR450 '03-08. Provides over 100 watts of DC power at idle. Regulator/rectifier included, battery sold separately.
  • swatdoc
Posted October 20, 2007 - 07:46 AM
yes, I have checked Trail Tech - the YFZ is a quad - we're on the motorcycle forum here - totally different system.
when I say I have researched this stuff extensively, I mean it. I didn't just go to the website and look. I actually called and spoke to the peole who design and make the components and asked them what was aailale, and even if they were going to make something in the future.
One sort of disclaimer - I am only talking about stuff available in the US - there is a company making a kit in Europe, but personally I would prefer not to deal with that.
  • rooster wrooster
Posted October 20, 2007 - 12:08 PM
Thanks for the update. I was going to get an electrosport based on one of your earlier posts. Let us know how the moose works. I am going to be getting one soon if they are any good.
  • akonibai
Posted October 20, 2007 - 02:45 PM
OMG.. thanks i was going to order that.. you save me.. thanks..
  • ThumperKid250F
Posted October 20, 2007 - 02:53 PM
yes please let us no how every thing works out.. by the way how much is the moose one.
thanks
  • ThumperKid250F
Posted October 20, 2007 - 02:54 PM
also if you could post pics of your bike with the kit you already have on it would be great.. thanks
  • YZ250F_Rider
Posted October 20, 2007 - 03:03 PM
so did you notice the trailtech description included wr250's and wr450's as well as the yfz450? Both of those are bikes.
http://www.trailtech...ystem_notes.pdf
  • akonibai
Posted October 20, 2007 - 03:36 PM
so does this mean's that we can use it on a 2006 yz450f motorbike?
  • YZ250F_Rider
Posted October 20, 2007 - 04:01 PM
It means you should do some of that extensive researching and call or email trailtech. the pdf file showed an aluminum frame and the description does say all years, but ask first.
  • akonibai
Posted October 20, 2007 - 04:07 PM
thanks i'll do that.
  • swatdoc
Posted October 20, 2007 - 08:05 PM
guys, like I said, I talked to all these companies. In fact I talked to Trail Tech again only a week ago. They still have nothing for the new 450's, and they still have no plans of ever making anything.
It is entirely possible that certain years of WR's and the quads have a similar stator setup, but the bottom line is it's different from the 06-07 YZ450F motorcycles, which is what we're talkin about.
Posted October 20, 2007 - 09:19 PM
The listing is: "Stator for Yamaha YFZ450 All Years and WR250/WR450 '03-08." They have no listing for the late YZ450.
The form factor of the YFZ (quad) stator is unchanged over this entire year range, and although the WR engines were changed in '07, they still use the same stator as they did in '03.
However, none of these will fit any YZ450 motorcycle engine unless some major parts are swapped into the YZ from the WR. In the case of the '06 and later, you "only" need the flywheel, stator, ignition cover, and crankshaft (or at least the left axle) from an '07 or later WR. In the case of the '05 and earlier YZ450, you need to add the crankcases to that list.
  • akonibai
Posted October 21, 2007 - 10:46 AM
so if i have an 06 yz450f i only need these parts
* 06 WR450F Flywheel
* 06 WR450F Stator
* 06 WR450F Ignition Cover
Posted October 21, 2007 - 11:56 AM
* 06 WR450F Stator
Re-read; you'd need the WR crank also, and the parts have to be from an '07 WR450, not an '06.
  • akonibai
Posted October 21, 2007 - 12:09 PM
ouch.. i'd rather not change my crank.. well just wait for swatdocs moose stator..
  • YZ250F_Rider
Posted October 21, 2007 - 02:01 PM
why the need for the crank half?
Posted October 21, 2007 - 04:54 PM
The WR flywheel is set farther outward from the crank in order to make room for the starter drive on the back side of it (if an e-start is installed). That means that the left axle of the crank is longer, for one thing, and apart from that, the taper is larger, by the look of it. Even if the taper on the YZ crank fit the WR flywheel, the flywheel would not reach out far enough to line up with the stator.
  • akonibai
Posted October 21, 2007 - 05:11 PM
so it's useless if we don't change the left side of the YZ crank with the WR crank?
  • swatdoc
Posted October 21, 2007 - 06:25 PM
correct.
It's gonna be WAY more expensive to switch to WR parts - plus alot more hassle since you'd have to split the cases and also press off and on the crank half.
A LOT easier and cheaper just to go with the replacement stator.
Only 2 advantages I could see in going with the WR parts swap - a perceived increase in reliability, and the fact that the WR stator no doubt puts out a lot more than 50 watts
