DR.D pipe on 2008 yz450f
28 replies to this topic
  • 917 rider
Posted October 31, 2007 - 05:05 PM
#21
917, your talking about your bike with a DR D and stock jetting? My 08 is almost perfect with the stock jetting. Pro circuit Ti-4 pipe. I only bumped the main 1 size and put the fuel screw at 2 1/4
yes my bike still has stock jetting,i was expecting to have to change it after all the reviews but i cranked it up and it runs perfect,crisp throttle,next to zero backfiring so i dont see the need. it also has way more power:banana: :worthy:
  • todds924
Posted October 31, 2007 - 06:49 PM
#22
Sweeeeeeeet! I like the way my 08 runs with stock jetting also. I only went up one on the main. Fuel screw at 2 1/4. On my 06 with a Dr.D, I only went up one on the pilot.
Posted October 31, 2007 - 07:24 PM
#23
That's true of both of my '06's, too. I put them at 45/165 before I ever rode them, then when they got their Dr.D's, I changed nothing.
  • todds924
Posted October 31, 2007 - 08:30 PM
#24
Hey Gray, I like the way my 06 runs with that set up but i've also tried an 06 with an NFLR needle that worked really well also. I believe thats the stock needle in the 07 and 08.
Posted October 31, 2007 - 08:42 PM
#25
The NFLR is the stock needle on '07-8's. The difference between that and the NFLP that the '06 came with is that the R needle is one half step leaner in any position than the P. I don't know that it would be that significant, but people say they like it.
Personally, as soon as my '03 sells, I'll try the Zip-Ty mod, and see how that goes.
  • todds924
Posted October 31, 2007 - 08:57 PM
#26
I'm pretty happy with the jetting on my 08 as it is right now. I have heard nothing but good things about the Zip -ty mod and was also thinking of trying it out. What exactly are they doing to the carb?
Posted October 31, 2007 - 09:32 PM
#27
The core of the mod is a modification to the main circuit in which the main air jet is removed, the passageway drilled out and tapped for a larger MAJ, and then a different emulsion tube is installed.
They also do the accel pump "wiring" mod.
There are add-ons like the Power Bowl, and Zip-Ty's accel pump linkage, hot start nut, etc.
The kit apparently originates from an outfit named Factory Pro.
http://www.factorypr...s/prodcy45.html
Scroll down the page until you see "Tech Tips" about a third down. Lots of details.
The results are, going by feedback only, and not FP's claims, generally crisper, more responsive carburetion across the board.
  • todds924
Posted November 01, 2007 - 05:19 PM
#28
Thank you for the info, its exactly what i wanted to know.:worthy:
  • Wes Woodin
Posted December 09, 2007 - 01:11 PM
#29
I'm not sure it the powerbowl has anything to do with the 52 pilot jet but it works.
First, he thought is was rich and tried a 42, much worse.
Second, tried a 48 and was better but not great.
Third, was the 52, what a difference!
The bike rips now with the 52, and powerbowl.
What elevation are you at?
  • Hot  47 replies
  • 0 replies
  • 10 replies
