DR.D pipe on 2008 yz450f
28 replies to this topic
  • mxdigger
Posted October 19, 2007 - 07:00 PM
Help........ Just put on my new DR.D stainless full system. Per Dubach Racing, I changed the main jet to a 162 and dropped the clip to the 4th position. It is now backfiring a little bit on decelleration, and it is shooting out flames when I hold it at about quarter throttle in neutral. Air leak??? Is there supposed to be a clamp on the header and tail connection. It did not come with one, and the stock one does not work. Also, the header pipe was glowing so bright, you could have lit a cigar. Is this normal. Any suggestions? Running it at sea level.
  • MotoXT
Posted October 19, 2007 - 07:52 PM
Same exact thing happened to me last weekend. Spoke with Dr. D and they suggest going up on the pilot. I'll be trying it tomorrow. The bike is supposed to backfire some, but as in your case mine was excessive. You can try going out on your fuel screw, but if you get too far beyond 2 1/2 turns go up on the pilot. There are a ton of threads on here with great info on proper jet set-up, so check them as well.
Posted October 19, 2007 - 08:06 PM
... it is shooting out flames when I hold it at about quarter throttle in neutral.
The pilot jet is too lean
No clamp.
The glowing header is semi normal, but is being exaggerated by the lean pilot?
  • Chilio
Posted October 20, 2007 - 05:27 AM
I had one of the first 08s in SoCal with the Dr.D pipe and I follow their instructions, 162 main and 4th clip position. Had a lot of backfiring on decel. I ended up going back to stock on the main and clip but I change the pilot to a 48, air/fuel screw is about 1 3/4-2 turns out.
Hope this helps.
  • matts06yzf
Posted October 20, 2007 - 03:23 PM
I changed mine also but changed back to stock I like it better at stock and of course keep my fuel screw Adjusted:ride:
  • Chilio
Posted October 27, 2007 - 06:42 PM
Alright guys, I haven't been very happy with the jetting on my bike with the DR.D. I met with Dean with R & D power bowl and he got my bike running great. I did get a power bowl and man that makes the bike so crisp.
Here are the specs
R & D Power Bowl
main jet 165
pilot jet 52
air/fuel screw 2 turns out
  • todds924
Posted October 27, 2007 - 07:46 PM
Here are the specs
R & D Power Bowl
main jet 165
pilot jet 52
52 pilot????????????? Wow. thats pretty big. How does the bike start when you stall it when its good and hot?? Where are you running the leak jet screw at on the power bowl?
  • Chilio
Posted October 28, 2007 - 05:25 AM
I couldn't believe I need a 52 either, but it works. I'm not sure about the leak jet screw, Dean set that up.
The bike starts so much easier, so much in fact my buddies in the pits noticed it.
  • todds924
Posted October 28, 2007 - 05:58 PM
Wow thats amazing. Are you going to be at I-5 Gorman in two weeks? I'll make sure to check you out then!!!! Went and practiced at Perris today. Dubach was there tearing it up. Sure didn't look like his 08 was hurting for power!!!
  • Chilio
Posted October 29, 2007 - 03:20 PM
I might go to Gorman but that is a really long drive for me.
I also heard about Dubach @ Perris, that guy still rips.
  • todds924
Posted October 29, 2007 - 03:40 PM
Hell yes he does. Vet x is at Racetown this weekend. Then Perris the next then I-5 Gorman. Races for the next 3 straight weeks.
  • kx1984
Posted October 29, 2007 - 09:19 PM
I'm up to a 48 with the DR. D on an 08 and it sure seems like it needs a 50 or better. I'm confused because the mags saisd it was killer with the stock jetting. Even before I put the pipe on it it seemed like it needed a larger pilot.
  • Ga450owner
Posted October 30, 2007 - 06:14 AM
agreed they all need a larger pj.....
  • Chilio
Posted October 30, 2007 - 06:18 AM
I'm not sure it the powerbowl has anything to do with the 52 pilot jet but it works.
First, he thought is was rich and tried a 42, much worse.
Second, tried a 48 and was better but not great.
Third, was the 52, what a difference!
The bike rips now with the 52, and powerbowl.
  • 917 rider
Posted October 30, 2007 - 02:51 PM
i put mine on my 08 450 with no problem runs perfect with stock jetting
  • matts06yzf
Posted October 30, 2007 - 05:07 PM
MIne too. I pulled 2 holeshots this weekend on it.
  • todds924
Posted October 30, 2007 - 05:34 PM
The largest pilot jet I have seen on any of the 450's 06- 08, is a 50. That was an 06 with a pro circuit pipe. I dont know if the powerbowl has anything to do with it- I dont see how it could. If it runs great i guess thats all that matters right. The only thing i'm very curious about is how your bike starts when its good and hot, like if you stall it during a race. I know when i used a 48 my 06 wouldn't start very well when hot.
  • 917 rider
Posted October 31, 2007 - 02:52 AM
first or second kick everytime hot or cold:thumbsup: :worthy:
  • todds924
Posted October 31, 2007 - 03:57 PM
917, your talking about your bike with a DR D and stock jetting? My 08 is almost perfect with the stock jetting. Pro circuit Ti-4 pipe. I only bumped the main 1 size and put the fuel screw at 2 1/4
  • Chilio
Posted October 31, 2007 - 04:19 PM
Todds, your welcome to try my bike at the next Vet-X race, with the powerbowl its like a different bike!
Motocross
  • Hot  491 replies
  • 0 replies
  • On January 15, 2017
  • 10 replies
