Replaced the stocker with a wiseco.The Cyl was honed with a flex hone,all the rings are assembled correct,timing is right.I put a dab of oil on the piston skirt as RHC advised.I shimmed all valves on the loose side except for the exhaust valve that is connected to the auto-decompression mechanism,I left it on the tight side.I put valvoline mineral 20w-50 oil in it for break in,I will change it to fs 10w-50 oil after break in.
Kicked the bike for 25 times without any oil in the engine,seemed to have less compression than the stock one did.Filled the engine with oil and kicked another 25 times,compression got better,problably because the oil helped the rings to seal.Dont get me wrong,the engine still got compression,just not as much as it used to.
Could this be because a forged piston uses larger tolerances when cold than cast ones?
