Mothballing the 600R
9 replies to this topic
  • Owyhee
Posted October 19, 2007 - 08:48 AM
I'm going to be storing my 600R for about a year and a half. Aside from the obvious (putting the bike on a stand, an oil change, and draining the tank) what else should I do ensure the bike remains as fresh as possible when it's time to revive it?
"O"
  • Denn10
Posted October 19, 2007 - 10:17 AM
fresh filter, maybe lube up cables too
  • ghrati ghoti
Posted October 19, 2007 - 10:23 AM
I'd remove the plug and put some oil in the cylinder, replace plug. Spray some type of oil over all metal bits. Armorall the seat. Put a tarp over it. Lube suspension linkage. Or send it to me and I'll keep it excercised for you.
  • martinfan30
Posted October 19, 2007 - 11:25 AM
stabil...
  • Owyhee
Posted October 19, 2007 - 12:53 PM
I've heard this before. Will any old oil do?
You'd be suprised how many times I've heard that...
stabil...
Will Stabil keep the carb from getting all varnishy?
"O"
  • ghrati ghoti
Posted October 19, 2007 - 01:19 PM
"O"
Your engine oil will do fine, kick it afew times before you put the plug back in.
I would drain the carb too.
  • Nummie
Posted October 19, 2007 - 01:31 PM
You can get a can of engine fogging oil at most automotive parts places; its good stuff to spray on all the steel parts that would normally begin to rust. Things like cable ends, nuts and bolts, springs, chain, etc....
You could also spray some armour-all or some sort of vynol protector on your seat and tires.
  • martinfan30
Posted October 19, 2007 - 01:46 PM
"O"
yes. i have heard that draining for that long causes another type of formation.
  • kheff46
Posted October 20, 2007 - 10:56 AM
battery tender or plan on replacing the battery? do you even have a battery i guess would be a logical Q!
JP weigel makes a product called frame saver which is suited for all steel surfaces and works really well(think PB blaster 'roids) for long periods of time. i use it on old bicycle frames inside the frame tubes(insert from welding weep holes).
--keith
  • BackinAction
Posted November 04, 2007 - 08:21 PM
I can attest to the oil in the cylinder thing. My dad did that to the '65 Harley before storing it for 20 years, and it started and ran without much more than fresh gas and several stern kicks. It makes for a hell of a smoke screen, though, when you start it again... don't be surprised if the neighbors call the fire department because it looks like your garage is burning down. Take pictures for future amusement.
