Is one tooth size noticable on the rear. 2007 yz450f
21 replies to this topic
  • Family Man
Posted October 18, 2007 - 07:05 PM
Im thinking about going to a 50 tooth for more snap or should I go bigger like a 52.:crazy:
  • Racer808
Posted October 18, 2007 - 07:53 PM
the 50T is noticable and still managable. Even with a 50T sproket you will be shifting more on the track. Not a ton more, but it will rev out quicker. With a 52T you are gonna be shifting all the time. But the tourqe will be phenominal
  • todds924
Posted October 18, 2007 - 07:57 PM
A 50 tooth is all you need. Anything larger would be impractical in my opinion. I alternate between the stock 49 and a 50 depending on the track. I prefer the 50.
  • Ga426owner
Posted October 19, 2007 - 05:11 AM
I prefer the 50 also on my 06:thumbsup:
Posted October 19, 2007 - 07:08 AM
You probably won't notice it as "more snap" any more than you notice more snap in second gear than in third. But where you will notice the difference is in those places on your favorite track where you now feel like you're "in between gears", where you feel like one gear is too low, but the next one is too high. It often takes only one tooth to correct this.
  • olympus
Posted October 19, 2007 - 08:42 AM
I just changed to a 50T on my '06. It makes a difference for me, especially coming out of slower 2nd gear corners.
  • Vinny2692
Posted October 24, 2007 - 03:02 PM
i really gotta get rid of my 45 tooth.. i land from a big jump and it just has not as much bottom end is id like... lotta top end though.
  • Yamahafan
Posted October 26, 2007 - 08:09 AM
A 52 tooth would be counterproductive because the rear wheel will break loose all the time unless you have a new tire and very good traction conditions.
  • stroker101
Posted October 28, 2007 - 05:01 AM
after reading this...lol, i think i may have gone up 1 tooth too many. i installed a 51T and the bike pulls better off the bottom, good for our shorter/tighter tracks. but i think on our larger/longer tracks it won't meet my needs. a 50T will be on order.
  • jbehunin
Posted October 28, 2007 - 05:46 PM
I put on a 52 tooth rear, and wow the difference it made to the low end.....
  • todds924
Posted October 28, 2007 - 06:04 PM
My friend races supercross and only uses a 51 on his YZ. 52 is huge.
  • Ga450owner
Posted October 29, 2007 - 10:09 AM
yikes a 45.....man lowest I like is the stock 49.
  • Polar_Bus
Posted October 29, 2007 - 11:14 AM
Cripes the 07' YZ450 pulls like 92 mph bone stock, and with a 45 tooth rear your bike should pull like 115 ? Why you running a 45T rear??
I have a 51T rear as I do a fair amount of woods riding, and the 51T made 1st gear WAY better in the slow, technical stuff
  • WB450
Posted October 29, 2007 - 12:12 PM
I went to a 52 for the same reason, I couldn't imagine a 45!
  • todds924
Posted October 29, 2007 - 12:26 PM
a 45 for what BAJA???
  • Ga450owner
Posted October 29, 2007 - 01:08 PM
or Bonneville SaltFlats...:worthy:
  • grunkthump
Posted October 30, 2007 - 09:33 AM
51T here on an 07' for GNCC/H.S.
  • bkklett
Posted November 01, 2007 - 08:09 AM
I have a 03 YZ450- even though I did not change the rear I did change the front. I was told that for every 1 tooth change in the counter sprocket- it = 3 in the rear. The best thing it was cheaper:ride:
  • rexbond007
Posted November 01, 2007 - 07:15 PM
i went 50 T and it wasn't enough, had to go 51 T have running it 6 months now.
  • briank3000
Posted November 01, 2007 - 07:48 PM
do you have exhaust? I run a 49 with a full bill's exhaust which complety woke up the motor.
