Cycra Probends Question...
4 replies to this topic
  • SouthernXer
Posted October 18, 2007 - 10:18 AM
I got a set of these today and am wondering how to connect them to the bar ends... They came without instructions. Do I need to drill the ends out to accommodate the insert and screw?
Thanks!
  • matt4x4
Posted October 18, 2007 - 10:48 AM
What kind of bars do you have?
They seemed to work fine in my Rethal bars without any problems.
http://www.cycraraci...echsupport.html
  • clark4131
Posted October 18, 2007 - 11:30 AM
The bars themselves most likely will accomodate the inserts without a problem. However, the throttle tube may have to drilled, but BE CAREFUL. When I did mine a few years ago, the end shattered and I had to go get a new tube. Big PITA...SC
  • SJMC_DON
Posted October 18, 2007 - 11:48 AM
I use a hack saw and cut like a 1/16" off the end of the throttle tube. Clean up the edges and it will work great!
Clark is correct I have first hand experience in splintering a throttle tube all to hell, 04' right out of the crate hadn't even ridden yet:bonk:
  • SouthernXer
Posted October 18, 2007 - 11:57 AM
Thanks guys.... I used a 1/2" bit and just drilled out the throttle tube end and everything fit and tightened up like a charm.
Now, to go test them. :crazy:
