xr600 spark, stator rewind
10 replies to this topic
  • bt08231
Posted October 18, 2007 - 03:30 AM
Picked up an old 87 xr 600 for 375.00 in decent shape, she turns over, but the spark is the sadest thing ive ever seen. Completly lame, so....im going to rewind the stator. Ive found some good articles on here about it but still had one question, i saw a guy on here who used 33 gauge wire, is that the stock size? if not is fatter sized wire better or worse? what size do you guys recommend i use? Ill let you all know how it turns out. thanks for the help
Brian
  • scalejockey
Posted October 18, 2007 - 04:12 AM
That won't help your spark.
Is there a problem of how it runs?
  • bt08231
Posted October 18, 2007 - 04:46 AM
it will make a much healthier spark, ive yet to get the bike to run, carbs were leaking so we disassembled and cleaned them (floats mainly, they were stuck open) anyway the spark sucks so a coil is on order and the stator is gettin rewound, i read that the heat and oil eventually breaks them down ruining the spark.
  • martinfan30
Posted October 18, 2007 - 06:48 AM
ive read several articles about rewinding to improve spark quality. am i delusional?:crazy:
  • cleonard
Posted October 18, 2007 - 06:53 AM
I'm the one that used the 33 gauge wire. I would go no larger than 32. The problem is that the voltage is determined by the number of turns. The stock machine wind is really tight. I don't think that I got nearly as many turns with my hand winding. The larger the wire the less turns will fit. The upside of larger wire is that it is stronger.
My bike starts great. However, due to the lesser number of turns I have to kick it harder to make it spin fast enough to make a good spark. I get first kick starts at least 50% of the time.
The best write up is at http://www.crustyqui...ech/stator.html
Since you are replacing the coil, I'd replace try that first and see if it makes any difference. It's not technically difficult to do the stator winding, but it does take some time and it will make your fingers hurt as you put turn after turn on there.
  • bt08231
Posted October 18, 2007 - 09:00 AM
awesome, sounds good, yeah that coil should basically just plug up and then well see if the spark changes. If not, rewind it is, so i guess ill go a little bit smaller than 33 gauge.
  • bt08231
Posted November 11, 2007 - 09:59 AM
another question, i dont have the parts in front of me to look at so bear with me this question may sound stupid, but when you rewind the stator, where exactly do the two ends of the wire go? I havent seen anything about this in the articles on the internet. Sorry if this sounds stupid but electrics baffle me....
  • cleonard
Posted November 11, 2007 - 10:40 AM
Connect the starting of the wind to the stator. This is then connected to the frame of the bike through the engine. Just solder to the existing connection. The outside of the wind is connected to the black with red stripe wire. Look at how the original winding is strain relieved and try to replicate it.
Take a look at that JAW/CrustyQuinns link that I posted earlier. It has lots of nice photos.
  • rmhrc630
Posted November 11, 2007 - 05:45 PM
Are you fer real dude?
Of course a rewind on a 20 year old bike known for stator issues will improve spark.
To the original poster - rewinding is the solution.
  • scalejockey
Posted November 12, 2007 - 05:48 AM
uh... whatever
Anybody know what a volt\ohm meter is??
  • martinfan30
Posted November 12, 2007 - 11:36 AM
a what?
lol
Honda XR650L 2017
  • 0 reviews
  • 22 replies
  • 3 replies
  • Hot  28 replies
  • Hot  141 replies
