08 WR450 License Plate Mount?
12 replies to this topic
  • beezer
Posted October 17, 2007 - 06:29 AM
Anyone know who makes one?
  • dmoney1074
Posted October 17, 2007 - 09:38 AM
Buy some aluminum, cut and bend it to fit the fender, then bolt it down... Done
  • beezer
Posted October 17, 2007 - 09:56 AM
My time is valuable.
I want to buy one.
  • b13
Posted October 17, 2007 - 10:38 AM
Yamaha make one a straight replacement for the original unit.
  • Island Boy
Posted October 17, 2007 - 12:45 PM
check this out:
http://cgi.ebay.com/...em=230147598085
I bought one from this guy, i think it was around 40 bux. Fits and looks awesome.
  • tweav
Posted October 17, 2007 - 04:30 PM
I have the one from motardrider also it fits great and looks the best out of all the ones I've seen.
  • jams229
Posted October 17, 2007 - 06:31 PM
check this out:
No offense to IslandBoy, but stay away from it!
I bought one, and I agree, it fits well and looks good...
HOWEVER, it will get ripped right off after you bottom the rear suspension a few times. It is poorly designed.
  • beezer
Posted October 18, 2007 - 09:25 AM
I guess I will have to make my own but under protest as I'm fat and lazy.
The ebay bracket looks over built though.
  • Island Boy
Posted October 18, 2007 - 11:35 AM
Get the one from Ebay, you will be pleased. I bottomed out and nothing happened to mine. I simply adjusted my sag and haven't experienced a problem since.
  • tnl
Posted October 18, 2007 - 06:19 PM
I just bought a UFO rear fender with a complete running/brake/plate light and a license plate holder all in one for $48 from a local bike accessory shop (cycle gear).
  • Humunn
Posted October 19, 2007 - 04:14 AM
Run a search on WR license plate brackets. I have an 07 and made one easily for $8 that is as good today as it was 8 months ago when it was new. I posted several threads about it. There are pics also. PM me if you have any specific questions. Don't go with aluminum - It will bend and eventually break.
Greg
  • chrispy1202
Posted October 19, 2007 - 02:37 PM
I had an aluminum bracket from a dualsport kit and it broke as they all do. Then i cut another piece of heavier material and used it and it broke also. Then i cut the same piece again, but where you make the bend down away from the fender, i cut it off an inch after the bend. Then picked up a piece of UHMW 3/16" thick and cut it to match the outside of the liscence plate and drilled two mounting holes.to reduce any extra weight on the fender, i cut the center out of the UHMW so only a 1" border was left. You will have to replace your liscence plate before you have to replace another broken mount. Unless you rip the whole fender off in a tank slapper. I have gone backwards into many a tree and my mount is still kick'n.
Cheers!
  • RSWR450F
Posted November 28, 2007 - 01:42 PM
Licence plate UFO with LED light:
