Xr650l Gear Selector Shaft Replacement
6 replies to this topic
  • mystubby
Posted October 16, 2007 - 04:31 AM
Can any body please tell me if there is an easy way to replace my broken gear selector shaft on my 2005 XR650L? Can it be done without pulling the engine completely down?
  • martinfan30
Posted October 16, 2007 - 07:31 AM
no, sorry. time to split the case.
  • machman
Posted October 18, 2007 - 12:38 PM
Yup, sorry to hear this, but you are into a full teardown.
Faced with a similar situation that I'm still in, I would suggest you open your wallet, do some research, and turn your XRL into a 50HP beast.
  • creeky
Posted October 18, 2007 - 12:45 PM
:crazy: The cases :D have to be :applause: split :bonk: .
  • martinfan30
Posted October 18, 2007 - 01:39 PM
ya in a sick kinda way i almost hope something happens to mine so i can justify to wife that i need to build a 50 plus hp xrl!
  • machman
Posted October 22, 2007 - 01:54 PM
I just split my case last night. It's not that bad. I strongly suggest you get the proper tools though. You'll need a 27mm socket, a 30 or 30mm socket, a case seperator, a clutch basket holder, and a flywheel puller. I got mine on ebay for $100.
  • mystubby
Posted October 27, 2007 - 04:34 AM
Thanks for all the bad news, I had my local Honda service agent quote me $1000 to do the job, $800 labor and $200 parts ($80 per hour!), Do your US bike mechanics charge that much? I promptly picked the bike back up to do the job myself. I have since stripped the engine down, and replaced the broken shift shaft ($77 Aust.). I have also taken your advise to add a few more HP while Ive got it in pieces. I have purchased a wiseco piston (10.25-1) kit, and a hotcams stage 1 cam. I am also planning on sending the head out to be ported and polished? Is there anything else i should be considering while its in bits? Oh, the other thing i know I want to add is a stainless header pipe (I already have a white bros. E2 pipe), Which make header should I go with?
