xr650l Clark 4.0 tank to much play
4 replies to this topic
  • stuntrider7x
Posted October 14, 2007 - 06:26 PM
Hi, i have a clark 4.0 on my 650l and all bolts are tight but the tank has a lot of play and moves aroung to much on the rubber an my petcok is hitting the engine when the tank moves, has anyone else hade this problem Thanks!!!
  • COAL RUN
Posted October 15, 2007 - 05:25 AM
I had the same problem with mine. My fix was to replace the wire that connects across the front of the tank with a piece of 1/8" flat steel about 3/8" wide, I put a twist in the center of this "bar" to align with the origanl "wing mount" locations, drilled the bar to allow me to thru bolt using the "wing mount" locations. This makes the tank rock solid.
  • ghrati ghoti
Posted October 15, 2007 - 07:17 AM
Good Idea!
  • stuntrider7x
Posted October 15, 2007 - 02:16 PM
Thanks Thats what i am going to do.
  • GIANTac1
Posted October 15, 2007 - 07:51 PM
Good Idea!
It works! Also try zip tying some foam to your frame under your tank.
