07 450 handgaurds
22 replies to this topic
  • garr87v
Posted October 14, 2007 - 11:47 AM
I just bought an 07 450, I'm planning on doing all the mods but the gray wire mod, not sure about that one yet. I was wondering what hand gaurds you guy's are using. I was going to get the d-flex from rockymountainmc but they don't fit. I took the ones off my KDX and they hit the clutch. If anyone has some pics that would be great. Thanks
PS I tried searching for this and didn't find anything:bonk:
  • jpoehls
Posted October 14, 2007 - 12:33 PM
I had the Accerbis ones installed, and they also hit the clutch. I had to cut down the clutch level a little (the round nob is removed and a tad more). It actually works good for the old 2 finger feather the clutch.
  • KennyMc
Posted October 14, 2007 - 01:06 PM
I use the Multiconcept Touring Handguards from Acerbis. They don't interfere with any of the controls. There is a picture in my garage that may be helpful.
  • FastRides
Posted October 14, 2007 - 07:54 PM
garr - check this thread out (and the one within) http://www.thumperta...ight=cycra shiz
Many go with Cycra Probends (I did, too) - they're a little more expensive, but well worth the money in terms of protection AND performance (have had several hard impacts from front and side and they're bomb proof). Good luck. :crazy:
  • ccoates445
Posted October 14, 2007 - 08:19 PM
I've been very pleased with my Moose handguards. I fall alot and they weather the storm.
  • Island Boy
Posted October 15, 2007 - 05:46 AM
what he said, I have the Cycra Probend Enduro guards (handlebar mount). A lot of TT members have expressed that the triple clamp mounts are better but i have no complaints about my set up.
  • mvryder
Posted October 15, 2007 - 03:54 PM
Its all about the Fastway handguards. They have replacement bar clamps and the guard mounts to those. Best system I have ever seen. Doesn't scar or damage the bars like every other bar clamping brand.
  • chevytrkn1
Posted October 15, 2007 - 04:27 PM
I also got the Moose wrap around on mine 07, Seem very stout. and are far enough out of the way to avoid hands and levers. Ill try and get ya some pics
  • gdm
Posted October 15, 2007 - 05:45 PM
Try Enduro Engineering. :crazy:
  • tweav
Posted October 15, 2007 - 07:52 PM
I've got cycra probends on my 07 duel sported wr 450 .they fit with all the extra
stuff on my bars I've got the clamp ons .I think the ones that replace the upper bar mount would fit just a little nicer and cleaner on my application , with the mirrors and the turn signal switch
  • CORider63
Posted October 15, 2007 - 09:00 PM
I have the Maier Deluxe Woods Pros and they work fine. I believe that the Tusk handguards at Rocky Mountain ATV are identical, but less expensive.
  • RickSanson
Posted October 16, 2007 - 05:17 AM
I have Moose which I modified by drilling a hole about 12mm inboard of the factory hole. This put the Moose bar mounts for the Pro-Taper a little further out making them fit the handlebar much better and provides a much stronger bond between the guard bar and the mount. It also shortens the guard bar a bit making it harder to bend.
I also used about 12mm of washers between the guard bars and the handlebar mounts that pushes the guard bars forward and away from the clutch adjustment.
It's like the hand guard and the handlebar are one piece!
  • TheBlackSheep
Posted October 16, 2007 - 11:13 AM
Ditto. I put the Acerbis ones on first and they flat out sucked.
After my frustration with the Acerbis ones, I shelled out the cash and bought the Fastway system. They are awesome. I couldnt be happier. They have already lasted twice as long and look nice and clean. Dont waste your money on anything else. It's all about the Fastway System. I got mine through the TT store for a great deal.
............. bahhh :crazy:
  • JSanfilippo
Posted October 16, 2007 - 11:43 AM
I've got the MSR bars and shields. Awesome bang for the buck :crazy:
  • SJMC_DON
Posted October 16, 2007 - 04:10 PM
+1 for the Cycra Pro Bends, my only suggestion would be the universal or "U" shaped mounts that clamp on to the handle bars. I don't know how well they would withstand a hard impact but the stadard 3D bar mounts get in the way of my clutch cable and limit the position options for the clutch perch. The tripple clamp mounts are a bitch with the head light and everything.
  • wizbangdoodle
Posted October 16, 2007 - 04:15 PM
I have the Acerbis with the triple clamp mount. I love the mount but the Acerbis can't stand up to much abuse. I was riding Reiter Pit this weekend, going up the Lake Isabel trail and just tipped over. The Acerbis bent like a pop can.
  • TheBlackSheep
Posted October 17, 2007 - 06:24 AM
I could've sworn somebody already said It's all about the Fastway System
.............. bahhh :D
  • SJMC_DON
Posted October 17, 2007 - 07:43 AM
Were you up past the old bridge to this point?
http://trav.smugmug....4#30045120-A-LB
You gotta love Reiter, what does not kill you makes you faster but it sure is a hard on your bike :crazy:
  • wizbangdoodle
Posted October 17, 2007 - 11:25 AM
We made it up to that bridge. There were about 5 guys on quads that said they were hiking from that point. I figured if they were hiking, we had better just turn around there.
What a day. I bent the Acerbis, bent my rear brake rotor, broke the start button and went for a swim. I don't think I have ever been fully submerged in all my gear before.
  • Bleeds_Blue
Posted October 25, 2007 - 07:08 PM
I have the Acerbis ones installed, and they also hit the clutch. I had to cut down the clutch lever a little (the round nob is removed and a tad more). It actually works good for the old 2 finger, feather the clutch.
I did the same thing, works good for me. Also had a set on my YZ, took a beating. Two thums up here.
