07 YZ450F Cam Trick?
11 replies to this topic
  • tksmith
Posted October 12, 2007 - 11:46 AM
I have been told by a friend that works on bikes that if you take and retard the exhaust cam one tooth on the YFZ450 it is the same as putting in a hot cam. It gives like a 20% power increase. Does anyone know if the is true? I would like to do it to my YZ450F but I am not sure if the engines are set up the same. Any light on this would be great.
  • Yamaha4lyfe
Posted October 12, 2007 - 12:02 PM
well dont try it until you get a go from a mechanic or your going to put a valve though your head
  • tksmith
Posted October 12, 2007 - 12:11 PM
ya that is why i haven't done it yet. My friend that told me that is a service tech. and they were doing it to a brand new 450 while is was standing there.
  • cowboyona426
Posted October 12, 2007 - 12:24 PM
Changing the cam timing is something that has been done on the YFZ QUAD, not the YZF BIKE. The quad comes with WR spec timing. Don't mess with the cam timing in your bike.
  • tksmith
Posted October 12, 2007 - 12:31 PM
that is what I wanted to know thanks a ton.
  • mulisha1760
Posted October 12, 2007 - 12:57 PM
ya i know its done to the quad but never heard of it on a bike
  • dewercs
Posted October 12, 2007 - 01:15 PM
i raced a yfz450 last year( only year on quads, back to two wheels!) and yes that was a mod for the quad, but do NOT do it to a yz450f, the reason that was done was to make the cam timing the same as a bike wich was for more top end, your bike is already timed that way
  • KJ790
Posted October 12, 2007 - 03:05 PM
The YFZ (quad) comes with the timing advanced to make it less powerful (same as the WR450). By retarding the timing one tooth you make it have the same timing as the YZF (bike) is stock. If you retard the timing on a YZF it will run like crap. Hotcams will add more power than a YZF is stock.
Posted October 12, 2007 - 03:54 PM
The advanced cam timing in the quads and WR's increases the low end torque and smoothness of the engine, too.
But since these are all auto decompression cams, there's another problem: when you change the cam timing, you also change the timing of the point at which the decompression pin will let the exhaust valve reseat. When you retard the cam in a quad or WR, you will quite often end up with so little cranking compression that the engine will not start. Yamaha deals with this by using shorter pins in these engines. Some modifiers will get around the problem by grinding a certain amount off the pin, but I cannot recommend doing this, since the finish put on the end of the pin may not be very good, and wear at the lifter could result.
Likewise, advancing the cam will cause the pin to seat the valve too soon, and it will be unreasonably hard to start.
The right way to do this is to use the cam from a YZ (year of your choice) in the quad or WR you're modifying.
  • Dolce_Grappa
Posted October 12, 2007 - 05:25 PM
Gray, Do you know what the camshaft profile is for the WR? Just wondering if it would be and option for the low-end issues everyone is complaining about with the '08's.
  • todds924
Posted October 12, 2007 - 07:50 PM
There is NO problem with the 08 once you ditch the stock silencer. Alot of people however like the mellow low end hit the stock pipe gives.
Posted October 12, 2007 - 10:06 PM
Not a good idea unless you just want to loose some power. The answer for the '08 is an exhaust system.
  • Hot  36 replies
  • 5 replies
  • Hot  30 replies
  • Hot  113 replies
