I Can't adjust my idle screw just spins do I......
6 replies to this topic
  • matts06yzf
Posted October 10, 2007 - 05:09 PM
Do I need to by another throttle screw as they call it? And is that baby a pain in the butt to put in, someone give me a little of what I have to look forward to. The one in it now just spins in circles and does nothing. This is on my 06
  • todds924
Posted October 10, 2007 - 05:26 PM
Hey Matt, they are not that hard to install. Just pull the plastic cover off the left side of the carb-where the cables go in.
Posted October 10, 2007 - 05:30 PM
If you mean the idle speed screw on the left side of the carb, then there are two reasons why it might do that. The screw you turn is connected to the screw that actually holds the throttle open by means of a spring cable. This cable could be broken, or the screw could be stripped at the other end. Or, if at one time you backed it all the way out, you may simply need to restart the screw back into the carb body. Hopefully, it's the last thing i said. Check it out.
  • matts06yzf
Posted October 10, 2007 - 05:59 PM
I think cable is broke it just spins with almost zero tension and yes its my idle screw but in micro fiche they dont call it that. what should I do Gray?
Posted October 10, 2007 - 07:21 PM
It's easy enough to verify. Well maybe not on an '06, but anyway, remove the throttle wheel cover on the side of the carb to expose the end of the screw. Turn the knob and see if the screw moves. If not, replace the "throttle screw".
  • matts06yzf
Posted October 11, 2007 - 03:18 AM
Is there a way to adjust it for the time being while my part comes in?
Posted October 11, 2007 - 05:38 AM
You would need to access the actual threaded part of the screw at the throttle linkage and turn it with pliers or something. If the cable is broken near the knob, you may be able to turn it with that.
  • Hot  94 replies
  • Hot  47 replies
  • Hot  36 replies
  • 5 replies
