List em!!!!!!:ride:
BEST Mods
Started by Nvr2Old, Oct 10 2007 02:57 PM
34 replies to this topic
Posted 10 October 2007 - 03:12 PM
For the 08 KXF450:
1. Springs and valving
2a. Dirt Trick's Ironman Sprocket 1yr warranty on wear! (www.dirttricks.com)
2b. RK Chain
3. Hammerhead shifter +15mm or +20mm
Nothing else needed. Seriously!
Ok, I completely over looked the very first thing I do....set up the suspension! bone headed this one, but it is fixed now.
2b. RK Chain
Posted 10 October 2007 - 06:27 PM
If you had cash just burning a hole in yer pocket and wanted to go balls to the walls this is what I would do:
MB1 revalve
White Bro's Aluminum Pro or Carbon fiber system
BRP lower chain guide (1 year warranty)
Fresh 756RR's tires front and back
Twin Air filters
Jetting kit (take your pick from who)
ASV levers
Works Connection Clutch Adjuster
DeVol Racing hole shot device (Slap shot)
Renthal Aluminum sprockets/Gold chain
and a friggin seat belt to hold yer azz in place, your gonna need it!!!
MB1 revalve
Twin Air filters
ASV levers
Posted 10 October 2007 - 07:34 PM
Probably boring, but the best mods you can do are suspension related. Revalving if necesary and proper spring rates.
Posted 11 October 2007 - 05:52 PM
Do the ap mod for throttle responce. I also did some minor port work when i had the engine apart( top end). Nothing major just cleaned up the casting and blended the seats. Definately snappier. Added one tooth to the rear sprocket, fmf powercore slip on and i'm on the second revision on the shock, which works awesome now, and the first revision on the forks. The forks still need a couple more shims to be perfect. Also pro circuit linkage, and slide the forks up in the clamps, i have mine at about 10 mm to the bottom of the fork caps. The bike is working very well now, my best bike ever.
Posted 14 October 2007 - 10:39 AM
I went to the Team Green web site and did everything they recommended. Jetting (changed main and leak jets), suspension ( two sizes softer rear spring, clicker settings) and gearing (13/48). This bike rocks!
Unless you are at the Pro level (or just have lots of disposable income) motor mods are NOT necessary.
Posted 16 October 2007 - 11:14 AM
er193 said:
Pic 3. (behind the radiator shroud) KDX220 radiator overflow bottle, Devol radiator guards/braces.
Hey man, where did you get that overflow botle? Can you post a picture without the radiator shroud? Thanks!:thumbsup:
Posted 17 October 2007 - 01:05 AM
Home made radiator braces. Haven't needed them but its good to know its there 4 when I do bite it.
Posted 21 October 2007 - 05:46 PM
No problem, here ya go. It's from a 2005 KDX220, you can order it from Kawi. It has a plastic tab that the shroud bolt goes through to hold it in place. Fits about 1/2" or so back from the radiator so it doesn't impede air flow. I had to slightly mod my rad braces to fit it. You see the old crease in the rad brace back from the screw? I flattened that out and put a new bend in it right by the screw. Everything fit fine. Been using it a while and never lose coolant. Thanks to art for telling me about this. I still owe him some gas for it. I take unleaded, high octane. :busted:
Posted 22 October 2007 - 09:17 AM
ASVs
Renthal Kevlar grips
RC bend bars "Low-Straight" (or Renthal "RM low". Stock bars are good,too!)
742FA/756 or Michelin MH3s
Renthal chain/sprockets (48-51 rear)
FMF Mega w/MDK Carbon/Kevlar Silencer (You can just get the regular slip-on...the various tips allow S/A and Quiet options...Stock is jus' LOUD)
Acerbis Green on Green shrouds.
180 Graphics w/our corporate logos, MDK, FMF, TLD, Dragon...etc.
MDK Motor 13.5-13.7:1...incl. their Carb mod's...I LOVE my MOTOR!
Some TI here-n-there...some Al. washers and what-not.
Safety-Wire Bolts, grips, cables ...etc.
'06 pegs/clevis's
Excel A-60s
Suspension re-vlaved/built by Todd Thompson w/KYB kit parts. For U SoCAl guys...ENZO!
'06 linkage.
H/D Bridgestone tubes (I ride in some rocky stuff at times)
Fresh stock seat when it starts gettin' soft.
No-Toil filters/Oil.
Sunoco 100 gas...ain't runnin' anything-else...especially with a "4" in it!
KawaChem Premium 4T engine-oil...filter every 3 changes (Kawi).
4-Speed for moto (And the Dunes)...5-Speeder is for off-Road.
'06 pegs/clevis's
Excel A-60s
'06 linkage.
Posted 23 October 2007 - 07:58 PM
er193 said:
No problem, here ya go. It's from a 2005 KDX220, you can order it from Kawi. It has a plastic tab that the shroud bolt goes through to hold it in place. Fits about 1/2" or so back from the radiator so it doesn't impede air flow. I had to slightly mod my rad braces to fit it. You see the old crease in the rad brace back from the screw? I flattened that out and put a new bend in it right by the screw. Everything fit fine. Been using it a while and never lose coolant. :busted:
That's a very clean set-up!
You might want to re-think the Devol radiator guards for motocross use though. I had them on a KX 250F and small rocks from other bike's roost go right through them and cause a lot of damage to the radiator fins over time. I have removed them and put the stockers back on.
Posted 23 October 2007 - 08:05 PM
Thanks Fred, sounds like I need to put some screen over them. :thumbsup:
Posted 27 October 2007 - 11:51 AM
Thanks a lot. Think it's time for some garage work in my green babe!:thumbsup:
