1st to 2nd gear ratio R VS L
9 replies to this topic
  • auron
Posted October 09, 2007 - 07:48 AM
I know the R is 1; 3.083 and 2; 2.2125
Can anyone check the L?
  • XR650L_Dave
Posted October 09, 2007 - 01:45 PM
Someone posted the whole set of ratios for the 600R and the 650L here a while ago.
Good chance to get handy with the search tool- try searching this forum for "600R 650L gear ratio" etc.
Dave
  • Phuzzy McPhuzzface
Posted October 09, 2007 - 06:37 PM
"If the women don't find you handsome, they should at least find you handy." --Red Green
http://www.thumperta...854#post2313854
  • Captain Midnight
Posted October 09, 2007 - 09:44 PM
Can't I change just the first gear only?
  • XR650L_Dave
Posted October 10, 2007 - 07:54 AM
You a 'LUGger?
Anyway, you can take an XR600R 1st gear (both 1st gears), and use it in place of an XR650L 1st gear.
If you use a 600R countershaft, you have the option of adding a kicker.
Dave
  • martinfan30
Posted October 10, 2007 - 07:59 AM
You a 'LUGger?
Dave
the 600 1st lower? you just need the 1st driven and drive gears only?
Posted October 10, 2007 - 07:24 PM
You a 'LUGger?
Dave
That sounds contradictory to what this poster claimed:
XR650L_Dave,
The ONLY difference between the XR600 gearset and the XR650L in terms of ratio is first gear. Second gear on up is exactly the same. The XR600R's 1st gear is slightly higher. Other than that, the gears are not interchaingeable between bikes unless you replace the entire gearset, including the main-shaft and the countershaft. I know... I tried!!!
Lemme know if I am not interpreting this accurately. Just curious since my '07 L seems to have a 'gnashy' sounding 1st gear, especially on downshifting into 1st.
  • Captain Midnight
Posted October 10, 2007 - 08:33 PM
I want to put the XR600 1st gears into my XR650L, so the spread between first and second is not so large. They appear to fit, but that post that said you must swap the whole gearset confused me.
  • XR650L_Dave
Posted October 11, 2007 - 07:50 AM
XR650L_Dave,
I thought I heard you could change 1st over from a 600 set- could be wrong.
There are 2 different kinds of XR600R countershafts- at some point they went from 6 splines to the higher number of splines like the XRL has (14?).
Maybe someone tried a swap from a 6-spline countershaft?
I'll have to claim ignorance beyond that.
Dave
  • cleonard
Posted October 11, 2007 - 09:40 AM
85-90 XR600 uses the six spline countershaft. The 91 and up use the same splines as the 650L.
  • 17 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  29 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  35 replies
