XR650L gearing
14 replies to this topic
  • radbrad48
Posted October 08, 2007 - 07:08 PM
Well, I finaly got all my goodies on my 07 XR650L. FMF Q2, Uni air filter, Dynojet kit, drilled the slide, and took all the smog crap off. What a difference in power. I see people are regearing there bikes. Most say to go to a 14/48. What is the top speed with this gearing. How would just dropping to a 14 in the front be. Also, the 55 pilot jet I bought was longer than the one I pulled out. Everyone needed to order the right one, so I took the long one to work and machined it to the right length and put a screw driver slot in it. What would of happened if I used the long one. Thanks for everyones help and advise. Thumper Talk is great.
  • martinfan30
Posted October 08, 2007 - 07:18 PM
i use 15/48 on mine. still comfy at 65 on the hiway without TOO much buzzing. 14/48 i guess would be like 15/51. i've had mine up to 80 on the hiway and it gets smoother vib. wise, but wouldnt hold it there for long.
  • radbrad48
Posted October 08, 2007 - 07:21 PM
Does the 48 fit without rubbing on the chain guide.
  • martinfan30
Posted October 08, 2007 - 07:29 PM
i did remove it. it seemed like a bit too much pressure on it. i have put 2000 miles on it since with zero issues. you would be amazed at how much lighter the 48 sprockett(JT) is over the stocker too. i know some have left it on(guide) and havent heard any problems that way either.
  • radbrad48
Posted October 08, 2007 - 07:40 PM
Thanks. I see you on here all the time. Do you have an answer about my pilot jet question. What happens when you run the long one.
  • martinfan30
Posted October 08, 2007 - 08:38 PM
you should be fine with that jet. i have not run the "long" one myself, but if you have machined it to fit, and it seats properly, why shouldnt it work. best thing to do is try it and adjust your fuel; screw to run at idle. you will know pretty quick if it will work, i think.
  • radbrad48
Posted October 09, 2007 - 10:19 AM
Thanks. It works fine. Everything was the same except the length. Took care of that.
  • martinfan30
Posted October 09, 2007 - 10:21 AM
it run good though?
  • Denn10
Posted October 09, 2007 - 10:24 AM
i need to get me a 14 front you got any extras martini??
  • martinfan30
Posted October 09, 2007 - 10:25 AM
no i sure dont, but do have plent 'o' beer!lol
  • Terez
Posted October 09, 2007 - 04:52 PM
I ran into the different pilot size issue too.
Most do, and the average Honda dealer simply gives you the blank stare!!LOL
There are 2 pilot lengths, the regular and the short.
The short pilot has a small s after the size.
The 650L uses the 55s pilot which is shorter.
To my knowledge the shorter pilot is to clear the main jet baffle so it isn't impeded. I think they are the same otherwise as far as fuel flow and fitment.
I think Dave on this site said he simply notched the main jet baffle to allow the use of the longr pilot a it is more common to find/order.
  • goblin127
Posted October 09, 2007 - 08:06 PM
I used the longer one also with out any problems.
  • radbrad48
Posted October 10, 2007 - 06:07 PM
Thanks again everyone. All you guys are a big help. It's nice when people have the answers you are looking for.
  • axarob44
Posted October 10, 2007 - 07:31 PM
Hey Radbrad. I ran into the same thing with the longer pilot. The long on is a series 21 pilot jet and the short one is a 26 series pilot. I got the same:confused: blank look from the dealer. The Dave's mod's here talk about trimming the slosh baffle so the long 21 series does not interfere with the baffle. http://www.4strokes....xr650lcarbmods/
  • DBM
Posted October 11, 2007 - 03:49 AM
I'm running 14/48 on my dirt and 50/50 set ups. It will cruise at 65 with no problems. This as fast as I want to go with full knobs and/or 50/50 tires anyway. On my steet set up I run 14/45.
DBM
  • Hot  29 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 22 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
