Steeering head bearing reminder!!!!!
30 replies to this topic
  • MotoGoalie
Posted January 15, 2008 - 10:44 AM
#21
Good info, Roland, thanks.
anyone know what metric size the steering stem nut is on top of the triple clamps for an 06 WR450?
31 or 32 mm?:banghead:
Posted January 15, 2008 - 11:09 AM
#22
It should be a 30. It should measure 1 3/16" in English.
The SSS forks on the '06 YZF were 32's, but as you well know, the WR doesn't use that fork. :banghead:
  • MotoGoalie
Posted January 15, 2008 - 02:24 PM
#23
Just to be sure, the steering stem nut, not the fork cap.
I know, the forks suck, sort of.:banghead:
Posted January 15, 2008 - 02:34 PM
#24
Yep, stem nut.
  • rmzRacer293
Posted January 15, 2008 - 04:19 PM
#25
lately i have noticed that when i turn my bars when on my stand with front wheel off the ground the bars dont turn smoothly... they have a choppy feel to them like it gets stuck for a sec but it loosens up and then turns more. does that mean my bearings are shot? its an 06.
Posted January 15, 2008 - 04:24 PM
#26
Probably. Better have a look.
  • bboyce
Posted January 15, 2008 - 05:05 PM
#27
Dang, I think im just an idiot! I have over 100 hours on my 06 and I never greased the bearings. :banghead: Something I was going to do, but completly forgot.
Thing is, my bike feels brand new..not notches in the steering or anything. I am going to tear into my 250f that I just got and grease them, but should I be afraid on the 450? BTW, I have never washed my bike with a pressure washer.
  • Ga426owner
Posted January 16, 2008 - 12:33 PM
#28
it means either your bearings are too tight and wore into the races causing ridges or there is zero grease in the top bearing.....plan on a replacement soon. The bars will stick if left sitting awhile.....
but this is the typical symptom for shot bearings.....
  • Ga426owner
Posted January 16, 2008 - 12:36 PM
#29
no but you probably need to check them, stuff them with grease and do not torque too tight - I would etch a mark on both the spanner nut and the top nut to make sure you do not over tighten:thumbsup:
  • TommyBoyee
Posted January 17, 2008 - 02:20 PM
#30
I feel pretty lucky. This thread made me pull the whole assembly apart. The bearings look as clean and new as when they were first installed. Whohooo
I didn't feel like changing any more bearings after doing all the link and swingarm units
  • bboyce
Posted January 17, 2008 - 05:07 PM
#31
I did them on my 250f today. That bike has around 10 hours on it and I was suprised how nasty the top bearings were, but the bottom was perfect.
I am afraid on my 450 of what to expect. I feel some play in my swingarm, so I was going to pull it off and see what is up, probably the linkage bearings. TO my suprise, the swingarm bolt is seized. So, thats as far as I got, and to top it off, I was going to change my sprockets, went to get my CS sprocket off, and cant get that off either. :cool: :applause:
  • Hot  113 replies
  • 10 replies
  • Hot  30 replies
