  • Instagram
Trailtech Vapor Tach issues
  • Please sign in to reply
35 replies to this topic
  • SXP
    TT Titanium Member
Posted May 08, 2008 - 05:49 AM
:eek: :p I have also problems with the tacho.I installed it like in the instructions i tried al the install options.tacho is going grazy jums around not stable at all.my bike is a ducati m900 .i wired the black en red wire directly to the battery.the tacho red to the spade of the coil and the black to the frame.the grazy thing is if i disconnect the black from the frame the tacho is still working.if i disconnect the red and connect the black it is still working .the tacho works with only one wire(red ore black it dossent mather) .is it not possible i have to swith pollarety of the main connection of the Vapor.maybe their is a wizkid outthere ho knows how to fix this problem.
Instead of connecting the wires to any terminal, try wrapping the tach wires a couple of times (keep the red and black together) around the high voltage wire going from the coil to the plug (I'm assuming yours is not an integrated coil-over plug setup).
  • maxtherat
Posted May 08, 2008 - 10:24 PM
I'll be setting up my vapor tomorrow. Do any of you have any tips that you have learned since this thread was started? It's going on a 01 wr426 w/ a baja designs dual sport kit. I planned on running the power off the part of the harness that already had a connector on it for a daytime head light bulb.I'm running the stock light. I also was going to connect the tach signal wire to the connector that supplys power to the coil. Is the power wire long enough to run to the air box if I need toi connect to the battery or should it get intercepted as it goes to the switch? Thanks in advance.
  • fox the Duc
Posted May 08, 2008 - 10:38 PM
I think i found the sollution.I connected the black wire from the Tacho to the grey wire of the ignition box of the first cylinder. This is the negative how is going to the HT coil.do not connect the red from the Tacho.It is working stable as a rock now. the ducati has no CDI ignition i think that was the problem.(I found the sollution on the site of motogadget.de this is a high tech firm ho makes motorcycle instruments with a golden pricetag.thy say that most of the streetbikes have a transistor ignition instead of GDI):p :applause: :eek:
  • fox the Duc
Posted May 09, 2008 - 05:00 AM
If you have a CDI ignition connect like in the instructions.If you have a transistorized ignition connect to the negative of the coil or ignitionbox.Most street bikes have a transistorized ignition recognizable by a negative and a possitive on the HT coil.CDI ignitions have only a positive on the HT coil(like most atv off road bikes and two strokes).Transistorized have a positive and a negative on the HT coil.On my ducati i only connected the black wire to the negative of the ignitionbox (grey wire)of the first cylinder and did not connect the red wire from the revcounter.It works stady as a rock super stable.Its a schame that a company like trailtech(with sutch a wonderful product) dont mention it in its instructions:applause: :eek: :p :applause: .sorry for my bad englich i am from belgium
  • RJB
Posted May 09, 2008 - 05:30 AM
Check this thread out from the YZ forum - my YZ is connected this way and works like a treat
  • maxtherat
Posted May 10, 2008 - 11:10 AM
So here's what I ended up doing. Tach signal grounded to bolt holding coil to frame and pos. attached to the terminal suppling power to coil. Worked great at that point. Power was pulled off the pre exist. connector in the harness(baja designs non-DOT kit) for a daytime running light and it was grounded to the ground lead that's in the harness. With switch on lighting worked great but, with the bike running the tach went crazy. I then moved the power supply ground wire to the chassis and then the lighting would only come on with the bike actually running . The switch alone would not turn it on but, this way the tach is not getting any interference while running. Also, I was concerned about the size of the wires so I first slipped them through some drip irrigation "spaghetti" tubing to protect them. I'm not to concerned about not being able to activate the back light w/o the engine running since I can still hit the button for the temporary lighting.
  • SXP
    TT Titanium Member
Posted May 10, 2008 - 12:08 PM
max - wrap both wires multiple times around the high voltage wire going from the coil to the plug cap. You are describing what I went through with my 400 which has the same coil on frame set up. The only thing that fixed the wacky tach readings was the above procedure.
  • maxtherat
Posted May 10, 2008 - 01:12 PM
SXP,
Since I regrounded the power supply ground to the chassis instead of the ground supplied in the harness the tach issue went away. I works perfectly now exept that the back lighting does not turn on unless the engine is actually running. With the wire hooked to the ground in the harness, the back light would turn on with just the switch being on. I can live with it this way since the tach works fine and there is temp back lighting off the internal battery. It's just weird how moving a ground wire from one point ot another will change things. Thanks, MTR
  • jbrooks26
Posted May 12, 2008 - 03:34 PM
That would tell me that your ground for the Baja Designs kit is not making good connection. Ground should be ground no matter where you connect it. If you are grounding through another piece of equipment however, then your ground could become unstable due to that equipment having some sort of ground fault. Hope this helps,
Josh
  • byggd
    TT Titanium Member
Posted May 12, 2008 - 04:02 PM
SXP
So you are saying to wrap both red and black around the plug wire, terminate the red there and run the black to the ground wire on the coil mount? :thumbsup: I set mine up per the instructions, got a wacked reading so went to 5 times (per the FAQ on their site) and it's better but still not stable. I'm getting power directly from the BD DS kits battery.
  • maxtherat
Posted May 12, 2008 - 04:29 PM
Where are you grounding your power supply lead at? When I did a test run getting power off the battery and grounding it to the battery as well I got crazy tach readings. The way I hooked it up, as previously described, the tach is nice and stable at idle and it responds well to increased RPM's. The back lighting thing is what's throwing me for a loop even though it is just fine the way it is.
  • SXP
    TT Titanium Member
Posted May 12, 2008 - 06:02 PM
SXP
Neither the black nor the red tach wire needs to be connected to any power source - they both terminate (open) on the plug wire. Just wrap both wires around the plug wire (the single, thick, round wire going from the coil to the plug cap) multiple times . One (or both) wires act as an inductive pick up to send a signal to the head unit. Just try it - it works, and you will get a stable and accurate rpm reading. I can't remember how/where I tapped in for power - I'll have to check when I get back home at the end of the week.
  • fox the Duc
Posted May 12, 2008 - 09:02 PM
First off all you have to know witch ignition your bike have.Then you know how to connect your vapor.If your revcounter is still jumpy after correct instal.Trailtech has a revcounter lead with a resistor build in.maybe this will help.
  • TomJ2
Posted April 20, 2016 - 02:59 PM
Count me in this crowd...
Called them, they were..., to put it nicely, not friendly ("you must be an idiot who can't install it right.") The guy carried on for minutes about how no one follows instructions (I did to a "T" except I soldered the ground wire for power to the harness ground wire that mounted at the coil and runs directly to battery negative), seemed miffed that I mentioned that I tried all the solutions people had online who had the same problem (like, "You're the first person I've heard of with a high reading and jumpy tach!").
Apparently, ground isn't ground (even hard soldered to a wire directly grounded to battery - through a soldered loop term) for Trailtech.
So after running a new harness and integrating this into it, I cut both power and ground, soldered new wires to both, then ran both to battery poss and neg, totally dedicated wires directly to batt. Same thing. 6k RPM showing for idle. And a bit jumpy.
For the sensor wire, tried everything from two to 6-8 wraps. Same.
Ran sensor wire away from any other wires or conductors, using zip ties to hold it away just to test if it might be picking up noise from anything else. Same.
At this point, and given the attitude at Trail Tech (Gosh..., speaking of tech, was one for mil-spec builds and repairs for a decade before another decade as an engineer - including a diesel cycle redesign in India, but..., I must be a dunce since I can't get a tach to work..., of course), they're getting this whole thing back.
Bottom line, I've mounted probably a dozen or more tachs and never had this issue. Because they can't seem to figure out how to coil out noise in their design or whatever it is, anyone with a problem with it is to blame.
The time spent trying to correct this is equal to three times the cost of this unit at this point. Time to stop, dissect the whole thing out, pack it up and return it, with a, "no more Trail Tech motto."
I'll run something else, but not paying for their product that's this hit and miss with people. And certainly not for someone to waste my time and act like they did on the phone.
Edited by TomJ2, April 20, 2016 - 03:02 PM.
  • stevethe
Posted April 20, 2016 - 03:26 PM
I never had a issue with a trail tech tach however I hooked mine up to the hot lead. Not wrapped around the plug wire. The only issue I have had was water intrusion from washing the bike. Now I put a plastic bag over the unit when I wash it.
  • JVP
Posted April 21, 2016 - 09:30 PM
This is why I stopped buying any Trail Tech crap.....
Edited by JVP, April 21, 2016 - 09:31 PM.
