Removing dried Loctite?
6 replies to this topic
  • dazzabb
Posted October 04, 2007 - 04:15 AM
Strange question I know, but anyone know if Loctite can be chemically removed / dissolved?
Easy enough to wire brush it from the bolts but what about the captive bolt holes where wirebrushing won't work?
I'm up for a new starter clutch and gear on my WR450 soon and it seems that a few poor punters have had big drama with the 6 bolts coming loose soon after re-assembly, possibly due to threads not being cleaned properly.
I want to avoid those same problems.
Cheers
  • NavyNuke
Posted October 04, 2007 - 04:31 AM
solvent, run a tap in the hole, both, or a dental pick with a 90 degree bend on the end thats short enough to fit in the hole and scrape the old stuff out. then blast with compressed air to force out
  • frogman
Posted October 04, 2007 - 04:42 AM
Yup, Navy's right, the only way to really get old locktite out is to run a tap down in there. That stuff gets hard as iron.
  • tmckeown
Posted October 04, 2007 - 04:54 AM
heating up locktite and it will turn up powdery
  • JSanfilippo
Posted October 04, 2007 - 11:29 AM
You can get the nylon wire brush attachment on a dremel and use that to get most of it off.
  • PBDBLUE
Posted October 04, 2007 - 06:44 PM
If you are going to chase the threads out with a tap make sure it's a good quality one and not some "poison dogfood/toothpaste, lead contaminated" chinese junk tap. That being said I use taps all the time to clean out the old loctite, etc. Works great.
  • Gadsen
Posted October 04, 2007 - 08:48 PM
I use a small pointed pick fro those pick sets. Even in bolt holes. A flat bottom tap works well also.
