WR Graphics?
25 replies to this topic
  • Greenroom
Posted October 03, 2007 - 01:29 PM
Will a graffic kit for the yz work on the radiator shrouds of the wr? I can't find anything for a 07 W450 but plenty for the yz.:confused: Any help would be appreciated.
  • markseaba
Posted October 03, 2007 - 01:34 PM
I am pretty sure NO. They are different. From what I have found there are about 4 to 6 choices out there for WR's
  • SJMC_DON
Posted October 03, 2007 - 01:38 PM
I have used YZ graphics on my 07 WR, they are close enuf and little or no trimming is req'd :confused:
  • Greenroom
Posted October 03, 2007 - 02:19 PM
:confused: back at ya for the help.:confused:
  • redswr
Posted October 03, 2007 - 02:29 PM
i used factory fx, the dx-1 custom name and #
  • 07thommi
Posted October 03, 2007 - 02:43 PM
That thing looks sweet!:confused:
  • redswr
Posted October 03, 2007 - 03:40 PM
thanks,
the front and rear fenders and the fork guards are all for YZ's i had to cut the top off of the one fork guard to get it around the speedo bolt.
  • woodswr
Posted October 03, 2007 - 04:24 PM
That is a sharp WR. I also have a 07. How did you polish the frame and swingarm?:confused:
  • redswr
Posted October 03, 2007 - 04:35 PM
started off with 80 grit on a palm sander and worked my way down to 1000 grit. (should go farther down maybe 1500). then i put a buffing wheel on my angle grinder and hit it with some rouge. took about 8 hours.
yamaha puts a really thick clear over the frame and swingarm. when you get it all the way sanded it should look pretty shiny but the buffer makes it mirror.
  • woodswr
Posted October 03, 2007 - 04:57 PM
Thanks Red, I 'll do it whenever I have to tear the bike down.
  • TheBlackSheep
Posted October 03, 2007 - 05:51 PM
Wow, I've seen those on the Internet, but never on a bike. They look good! :confused:
................. bahhh :confused:
  • w00dsRider
Posted October 04, 2007 - 03:36 AM
Where did you find the graphics for the WR's? I have an 06 and have found only one choice, well two if you count the stock stuff.
  • yamaslamma
Posted October 04, 2007 - 07:53 AM
Why on earth would you start with 80 grit!!!!:confused:
  • drtbk4ever
Posted October 04, 2007 - 11:24 AM
Check out this thread
http://www.thumperta...ad.php?t=463671
I like the ones from XGX
  • markseaba
Posted October 04, 2007 - 02:37 PM
Factory FX, did have 2 choices
One Industries, I think only one choice which is what I picked
XGX Racing, has a few chioces
Hope that helps!!
All I know is that on a cold morning out in the desert I walked out to my bike and chunks of the stock graphics were on the ground. Basically, they got cold and cracked, could not believe my eyes.
  • weathergeek
Posted October 04, 2007 - 05:47 PM
Hope that helps!!
How cold was cold? We were out last year and it got down to 3 degrees for two nights in a row? What year is your bike? Mine is a 06 wr 250f. I'm wondering what else if anything could have caused it.
  • Gadsen
Posted October 04, 2007 - 08:42 PM
Agreed. :confused:
  • redswr
Posted October 04, 2007 - 09:43 PM
see the second line of my post...
its really hard to get through the clear coat...
ps: now i'm doing the clutch cover and the oil filter cover... didn't need to sand it with 80, the 600 worked fine then went lower.
  • suzukipoo
Posted October 05, 2007 - 06:02 AM
  • markseaba
Posted October 05, 2007 - 06:25 AM
it was in the high 20's. I was SHOCKED when I saw it. Called my buddies over and asked what they did to my bike, they laughed. They were very brittle, cracked and large chunks fell off. :confused: I had only had the bike about 30 days. I even went back to the dealer asking about replacement and got the, those are junk anyway, real bad in cold weather. It is an 2007 WR
