jd3020 said:
Progressive Suspension Springs from XR's Only, how do they rate? (Pun or no Pun)
I see that xrsonly.com has progressive Suspension springs for my 1990 XR250R. Would this be a good suspension upgrade for the bike? My springs feel kind of weak to me, but that may be just the way they normally feel. Would the xrsonly springs be a big improvement over the stock springs (even if the stock springs are working as new)?
Personally I would not recommend the fork springs, but I would endorse the shock spring. Progressive springs are not only Progressive in name but in nature. Much of what you need depends on what you want. Are the springs too soft and sag too much when you sit one the bike? Is it too stiff initially bottoms easily? I am guessing that they sag too much AND bottom easily.
The fork springs are just that, progressive, and as far as I remember they are a 20/30 lb/in rate. The problem is that even with the Progressive Spring in the fork, they sag too much in the initial travel and you are in the same position you are in now. Stock fork springs with an increased oil level will get you to the same place the Progressive fork springs will get you to.
I would recommend going to the Race Tech site, using their suspension calculator to determine the corrent spring rate for your weight and riding type and then buying Eibach straight rate springs since they have a shorter spacer than the Race Tech. These will provide you with a correct ride height and stiffen up through the stroke.
The Progressive shock spring is a good improvement, but a progressive rate on a rising rate suspension is kind of an odd fix. I have used the Progressive rear spring and liked it with valving, but I have also used a stiffer straight rate spring and found that not only did the sag and ride height fall within range, the bottoming resistance was better.
