Best XR250R aftermarket exhaust opinions ?
10 replies to this topic
  • D1k
Posted 02 October 2007 - 04:32 PM
Hi guys,
I've finally decided to get an aftermarket exhaust. I am tired of the loss of power because of the stock exhaust's small opening and am also tired of the loudness from the Unbaffled stock exhaust. I have the following: 99 XR250R with full Gordon Mods, 280cc kit, Mikuni TM34mm carb, HotCam stage 1, ground headers and matched ports. The bike is a great little Tiger in the woods.
What I am looking for is an exhaust that will flow the MOST without making too much noise. Also, this winter I will most likely make it a 320cc engine. I have been searching Hi and Low and have not found my answer yet, hence the reason for this post. I am not so worried about price but more with maximum FLOW and around 96-99db sound level.
Xrsonly.com has a stainless pipe that is sold as a "performance minded racers throughout the world" and is $279. TT has the Big Gun Evo that is $319. FMF has the Q series around $350. Thumper-Racing.net might have something but I have not seen it. May have to call them.
What are my options and I would like to know what others with similar setups are running for exhaust.
Thanx,
  • D1k
Posted 03 October 2007 - 12:29 PM
Bump........please ??
  • oregon_rider
Posted 03 October 2007 - 01:18 PM
If you can find a white brothers e-series pro-meg, they work quite well - I found one on e-bay. White Brothers is no longer producing or selling this pipe. Otherwise, just buy a baja designs baffle and "be happy". Most aftermarket pipes actually produce less power than the stock pipe with the baffle removed or with a baja baffle.
The e-series is loud - but a quiet baffle is available.
jeff
  • D1k
Posted 03 October 2007 - 02:15 PM
I will look at BD, see what you talk about.
tanx,
  • ttr125l95
Posted 03 October 2007 - 02:17 PM
Im running a yosh on mine, its not too loud.
  • mrxr250rider
Posted 03 October 2007 - 04:37 PM
my procircuit t-4 sounds good and isnt any louder,probably a little quieter than my unbaffled stock exhaust. its really quiet at idle but decently loud when you crack the throttle,i noticed a good power increase over the stock unbaffled.
if the big gun evo comes with the header id say try that out,if there are good reviews on it. i was gonna buy a used one on ebay to test against my t-4 but it went too high.
  • mrxr250rider
Posted 03 October 2007 - 04:52 PM
heres some prices on ebay for ya.
theres a used fmf powercore and stock header for 100 shipped(as of now)
new fmf powercore 4 for 240(lowest price ive found on ebay) shipped
new procircuit t-4 for 325 shipped
new fmf q2 for 295 shipped.
new procircuit 496 for 435 shipped
just figured ive give you some more options.
  • Honda_Rider_XR
Posted 03 October 2007 - 10:37 PM
Supertrapp is also a pretty good choice. I really like the disc type exhaust systems because of their tunability. It doesn't take much to add/remove discs depending on the situation.
That said, the WB E-series pro meg is pretty good, but loud.
  • jcr41
Posted 04 October 2007 - 04:16 AM
I second the t-4, I bought the quite tip for mine and its not loud at all, but has a great sound
  • D1k
Posted 04 October 2007 - 07:18 AM
Thanx for all the replies guys!! Have any of you ever gone the 320cc route? That is my main concern. I wonder if getting something for the XR400 might flow more for the 320cc piston kit?
  • Peterx2
Posted 04 October 2007 - 11:40 AM
Hi D1k,
I used a FMF Megamax II.
It has a disc type system (like the Supertrapp).
The FMF has also a Quit Core included.
Without the Q-Core it sounds like a big fat 4stroke. :D
Well, really a nice exhaust.
Otherwise, I also figured out that also the stock exhaust works well. Removing the whole baffle didn´t work good. (too much noise and bottem end lost)
Still modify the baffle insert a little bit for more flow; doing this will not make much noise and works fine.
(i also use a 280cm kit)
Peter
