Calling all XRL guru's
6 replies to this topic
  • Frank ZX
Posted October 02, 2007 - 03:12 PM
Hey Guy's,I found a CRF450 front wheel.I know the wheel is different.What I need to know is can I put my XR650L wheel bearings in the CRF450 wheel to make it work?
  • Frank ZX
Posted October 02, 2007 - 04:53 PM
Come on, someone's got to know!
  • cleonard
Posted October 02, 2007 - 05:53 PM
I think that you can forget it.
450X uses a 6904 bearing that is 20mm x 37mm x 9mm
650L uses a 6003 bearing that is 17mm x 35mm x 10mm
You would need to find a bearing that has a 17mm ID and a 37mm OD. Don't think you are going to find it. Not 100% sure if a 10mm wide one would work or if you would need to find a 9mm wide one.
  • Denn10
Posted October 02, 2007 - 06:27 PM
Just buy the front forks and the wheel will fit i GUARANTEE that LOL make an awesome front upgrade too!!
  • Frank ZX
Posted October 02, 2007 - 10:06 PM
Thanks Guy's for your help!I guess I'll let this one get away
  • machman
Posted October 03, 2007 - 07:23 AM
It wouldn't be that much work if you really wanted to do it. There are two options:
-Call a bearing company like Motion Industries and ask them if they have a bearing that matches the required parameters
-If not, have a machinest build you a sleeve to increase the effective ID of your axle
After that you may need to do some work building spacers to center your wheel and a bracket to relocate your caliper, but I'm not certain about that.
  • martinfan30
Posted October 03, 2007 - 07:33 AM
just try to find cr forks with the wheel and brakes. then you can find the rest that you will need at emigracing.
  • Hot  186 replies
  • 4 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  29 replies
