I recently purchased a 96' XR400 from a guy who had it less than a year. The bike ran great up until I took it to the shop to have the valves checked/adjusted. I also had them check why the bike was hesitant to return to idle. The shop adjusted the valves and told me the throttle cables were bad, which I replaced myself.
Now the bike hesitates off idle, enough that the motor will die if I'm not careful. I didn't check the performance before I changed the cables, so I'm not sure if I screwed something up or if the valve adjustment caused the problem. Also, the change didn't fix the return to idle problem. The idle problem is intermittent, so I know that the idle adjustment is not the issue. I lubed the cables thoroughly before installation, and the throttle housing is clean and lubed.
I'm going to remove the carb and clean accordingly, but I'm not sure if there are any specific areas to focus on regarding the problems I'm having...
1. The hesitation off of idle
2. The slow return to idle
Any information is greatly appreciated.
