Can't ride for 6 mth.rebuild or not to rebuild
28 replies to this topic
  • knuklehead
Posted September 30, 2007 - 06:00 PM
My trusty 01 650r has at least 20 thousand on it (still runs great).I won't be able to ride for a while,thinking I could freshen her up while I recupe,or just leave it be??? Havn't done any internal mods just fresh oil, filters and valve adjustments(not that many but checked often)Rode very hard all the time.What do you guys think??
  • XR4DEZ
Posted September 30, 2007 - 06:31 PM
My valves got to the point that I did not have any adjustment left and they needed setting after a couple hundred miles. Don't wait till it goes that far. If you don't have to adjust the valves frequently, you're still good. I had 19K on mine. Usually a rebuild and valve job is recommend around 12K, but mine still ran good right to the end. I'm glad it didn't blow before I had it rebuilt.I couldn't believe how much better it ran after the top end and valve job.
  • weskc35k
Posted September 30, 2007 - 11:44 PM
Do it.
Say you don't and go for a ride after you recover and it shits itself,you'll be pissed off.
  • scalejockey
Posted October 01, 2007 - 04:55 AM
Just do it. I notice every time my bike starts to not want to start on the first kick I adjust the valves(about twice a year) and the magic comes back. So they must be picky on valve condition.
  • machman
Posted October 01, 2007 - 06:14 AM
6 mos is a long time. It's easy to come up with the time and money required for a build over that much time. The other great thing is that it's over winter. ...I've been rebuilding from May-Nov:bonk:
  • cleonard
Posted October 01, 2007 - 07:09 AM
I'm usually part of the "if it isn't broke don't fix it group." However, at 20,000 your rings might be ready for replacement.
  • Denn10
Posted October 01, 2007 - 08:00 AM
YEP i agree with everyone take your time and its something to keep ya busy and when your ready to ride youll be on a nice freshy that you can enjoy for another 20K
  • martinfan30
Posted October 01, 2007 - 09:21 AM
ya do it. give you something to do while at home. maybe cam/hicomp piston? what is stock comp?
  • XR4DEZ
Posted October 01, 2007 - 09:33 AM
If you ride tight stuff or rox don't do the HC piston. It makes the bike more likely to stall and you'll have to clutch more.
  • weskc35k
Posted October 02, 2007 - 12:02 AM
Rubbish.
  • XR4DEZ
Posted October 02, 2007 - 09:12 AM
Another good reason to stay with the stock compression is to avoid using race fuel. It's nice to be able to use pump gas especially in remote areas like Mexico.
  • knuklehead
Posted October 02, 2007 - 05:19 PM
Thanks for all the replys.Soon as I get out of this Halo I'll pull the ole girl apart.Will just go with a 680 and mild comp.don't need that much more power.Goes faster than I need to go now!
  • XR4DEZ
Posted October 02, 2007 - 07:36 PM
Get well soon!
  • cleonard
Posted October 02, 2007 - 08:17 PM
Don't stop at the engine. Clean and regrease the swingarm, the linkage, and the head tube bearings. Perhaps paint? Make it like a new bike.
  • XR4DEZ
Posted October 03, 2007 - 07:12 AM
Good suggestion, watch those needle bearings.:confused:
  • knuklehead
Posted October 03, 2007 - 07:53 AM
Just had the swing arm off before my crash so I know its good to go,but will do service on fork, shock,and wheel/stem bearings.
  • XR4DEZ
Posted October 03, 2007 - 09:09 AM
I should probably of said I found the 650 does not lug down as well with a HC piston. JMO
  • weskc35k
Posted October 03, 2007 - 04:03 PM
rubbish
  • XR4DEZ
Posted October 03, 2007 - 04:13 PM
rubbish
Sorry, I'll acquiesce to this superb line of reasoning.:confused:
  • weskc35k
Posted October 03, 2007 - 05:31 PM
rubbish
  • Hot  60 replies
Which thumper motor for a street tracker? by woz
  • Hot  29 replies
  • 7 replies
  • 22 replies
  • 2 replies
