Clutch lever rattle after removing OEM handgaurds
12 replies to this topic
  • slowxr
Posted September 30, 2007 - 10:46 AM
After removing the oem handgaurds on my XR650, the clutch lever has alot of play at the pivot point.
Is there a fix for this? The noise is annoying.
Thanks
  • trippinwilly
Posted October 01, 2007 - 10:47 AM
I have the same problem, I think there is a mod over at 4strokes in the technical section that will fix the problem. If not, I am going to try to find a small washer and just shim it until it stops rattling. Just making sure that it does not make it catch and it still moves smoothly.
James
  • tmartinLVNV
Posted October 01, 2007 - 10:56 AM
Mine did same thing. Just get a big pair of channel lock plyers and squeeze the mounting bracket. You can bend it just enough to stop the rattling.
  • Denn10
Posted October 01, 2007 - 10:57 AM
or fit with washer maybe so you dont have to bend it?
  • squatpuke
Posted October 01, 2007 - 03:52 PM
My XR650L clutch lever rattles vertically w/the handguards ON if tI take my hand off the handlebar...ok with when both hands are on.
  • sj269
Posted October 01, 2007 - 04:22 PM
Thinking it might be good to use nylon or brass washers? Would a SS washer wear the aluminum clutch assembly too much?
  • scalejockey
Posted October 01, 2007 - 07:36 PM
I used a small O-ring with a little greese.
  • slowxr
Posted October 02, 2007 - 09:35 AM
Good info.
Thanks guys.
  • martinfan30
Posted October 02, 2007 - 12:13 PM
:confused:
yes.:confused:
  • martinfan30
Posted October 02, 2007 - 12:14 PM
very good idea!
  • XR650L_Dave
Posted October 02, 2007 - 02:11 PM
The O-ring is good because it will allow the lever to move a bit when the bike goes down. Might save a break.
My lever moves up and down a lot- its great, its always in just the right place whether I'm sitting or standing. Must pivot vertically 2 inches, at least.
  • RJCXR600
Posted October 02, 2007 - 06:33 PM
Try teflon warshers of different thickness.
  • trippinwilly
Posted October 03, 2007 - 07:48 AM
Check out this link. It will make it look better, and it might stop it from rattling(sp).
James
http://www.4strokes....honda/pivot.asp
