101 MPH on a 2007 YZ450F
28 replies to this topic
  • DesertRacer2
Posted September 29, 2007 - 06:44 PM
My brother and I went to El Mirage today in CA. The weather was nice and our bikes ran great. We both have 07 YZ450's. Our bikes are geared 15/48 for desert racing. On the lake bed, measured with a GPS, our bikes hit 101 mph. We tried it multiple times and the gps would keep recording 101 mph. Just thought you guys might find this interesting.
  • tommyj
Posted September 29, 2007 - 07:41 PM
i'm glad you're still with us......:confused:
  • Justin89
Posted September 29, 2007 - 08:03 PM
I second that
  • 642MX
Posted September 30, 2007 - 06:18 AM
Wow, so was it on the rev-limiter in 5th gear?
  • IDAHOBALLER
Posted September 30, 2007 - 06:36 AM
Do you run a steering damper?
I would think it would be crazy twitchy at those speeds!!!!:confused:
Posted September 30, 2007 - 07:40 AM
It would have needed to turn at or near 11K to reach that speed with that gearing, depending on how much rear tire slip was going on (there's always some)
  • mikedabike
Posted September 30, 2007 - 08:13 AM
According to my gearing calculator, with 15/48 you should hit 109 at 11000 RPM. That will never happen because of several things, wheel slippage, aerodynamics and power falling off at upper RPM. 101 sounds reasonable. My 04 with that gearing would bang the rev limiter on the dry lake while still pulling hard but of course it was a four speed so it would be around 90MPH.
  • Britincali
Posted September 30, 2007 - 08:40 AM
Ty davis was hitting 108 on his YZ at the adelanto GP a few years back.
  • Zendog
Posted September 30, 2007 - 08:42 AM
i had my crf up to 93
  • motomanmike26
Posted September 30, 2007 - 09:06 AM
i had my old stage 3 kx125 up to 103. its hard to believe for a 125 but it had a built engine it was fast
  • DesertRacer2
Posted September 30, 2007 - 09:22 AM
Yes, it was bouncing off the rev-limiter, however, I didn't hold it on that long.
  • DesertRacer2
Posted September 30, 2007 - 09:23 AM
Yes, I have been using a Scotts steering damper for 5 years now. I can't imagine riding without one now.
Posted September 30, 2007 - 01:32 PM
It depends on what you put in for a rear tire diameter. 27 inches gets you 109.36 at 11K, as you said.
Your '04 was not only a 4 speed, but had a primary ratio of 2.818 instead of the higher 2.652 that is used in the '05 and later models. That's roughly the difference of one full tooth on the front sprocket. The "on paper" top speed at 11.5K would have been 97.5, with no allowance for wheel spin.
Anyone who doesn't think that the rear wheel slips at high speeds should consider this case. He hit 101 on the rev limiter, which we know is 11,500 rpm. At that RPM with the gearing he has, and a 27" tall rear tire, the rear tread speed was 114 mph. That's an 11% loss.
  • IDAHOBALLER
Posted September 30, 2007 - 06:07 PM
I really want to put one on my 08 pretty bad since I mostly ride desert and sand dunes with a little mountain trails thrown into the mix every now and again.
Hauling ass in the sand dunes gets kind of sketchy when it starts to get headshake in 4th and 5th gear.
I am torn between the scotts damper and the GPR damper but I dont have any experiance with either one on a bike. Have you ridden a bike with a GPR damper to compare to the scotts?
Thanks:applause:
  • DesertRacer2
Posted September 30, 2007 - 06:34 PM
Thanks:applause:
I personally have not. However, a friend of the family had a YZ450 with a Scotts and a KTM 450 EXC with a GPR and he said the Scotts was superior. I have dealt with the staff at Scotts for many years and their customer service is great. Once, my damper had a little bit of black grease near the top of the armature, nothing major at all. I called them up and they rebuilt it for me at no charge.
Posted September 30, 2007 - 08:31 PM
Notwithstanding the fact that their customer service is top notch, The Scotts is adjustable for overall resistance, for sweep (left and right independently), and only Scotts has a high speed damping valve, also adjustable. The difference they make is amazing.
  • cmichael
Posted September 30, 2007 - 10:58 PM
i raced my friends r6 and he had me at 99.
  • hall1012
Posted September 30, 2007 - 11:32 PM
How fast is a 2007 YZ450 with a stock front sprocket and a 50T in the back?
Posted October 01, 2007 - 06:17 AM
On pavement, about 85 at the power peak, 92 or so at the rev limit.
  • leanin
Posted October 01, 2007 - 07:29 AM
Dirt Rider put the '07s on a dyno and ran them to top speed. Here's their #s
CRF450R - 91
KX450 - 90
KTM 450 - 84
RMZ450 - 77
YZ450F - 84
The YZ gearbox ratios are spaced very evenly.
1st - 42, 2nd - 52, 3rd - 63, 4th - 73 and 5th - 84.
  • Hot  36 replies
  • Hot  30 replies
  • 0 replies
  • Hot  50 replies
  • 5 replies
