Xrl puffin blue on deaccelaration
26 replies to this topic
  • Boy named sue
Posted October 02, 2007 - 12:30 PM
#21
what do you use for the oil tube from case to cyl. head?
Stock tube.Often wondered about that but figured the oil pump must be engineered for that size tube.
  • truck6driver
Posted October 02, 2007 - 12:58 PM
#22
you go with stock cam/rockers, or aft. mkt.?
I went stock cam and rockers and Kibble White on the guides and valves.
RH
  • martinfan30
Posted October 02, 2007 - 01:27 PM
#23
Ive stripped a fair few XR/XL engines and never had a problem with guides. I find the exhaust valves wear, the valves faces wear but overlal cam wear and rocker wear usually the limiting thing.
Fitting Kibblewhite guides/valves should make no difference to service intervals, you will still need to check valve pocketing and cam wear no matter how good the parts are.
I find my race motors smoke quite bit on start up but settles down once run upto temperature. Think its prob'ly the fairly generous side clearances on the 102.4mm wiseco.
Worth bearing mind that you can get oil pumping down the valve guides on high lift cams, but not generally a problem until you go to the extreme 12mm+ lift cams that megacycle do.
did you stick with the stock oil tube from the cyl head to the case?
  • crmc33
Posted October 03, 2007 - 03:25 AM
#24
I run a HEL swaged braided line from the case to the head, the flow limiter is the banjo and bolt holes, I changed it since I dont like the kinks in the original Honda item.
I can get more lines if anyone requires one. Postage from the UK might be cost prohibitive tho??
I think the ideal is a transparent tube so you can check oil flow very easily!
  • martinfan30
Posted October 03, 2007 - 01:02 PM
#25
limiter come with the hose? Yes i'd be interested in one. can you give a cost maybe?
  • crmc33
Posted October 04, 2007 - 04:41 AM
#26
what I mean is that the holes in the banjo bolts are as per the original item so even if the hose is bigger bore then it wont flow differently to the original Honda Part. Ive had no issues with my line on the race engine.
I will get a price for one....and post a pic
  • martinfan30
Posted October 04, 2007 - 08:06 AM
#27
i thought so but wasnt sure, ok. thanks.
  • 17 replies
Honda XR650L 2016
  • 0 reviews
  • 22 replies
  • Hot  186 replies
