XR650L oil tube restriction?
5 replies to this topic
  • wheelnut46
Posted September 26, 2007 - 04:24 PM
Anyone ever give any thought to how thin that little chrome tube is that goes from the oil filter housing up to the head? I often wonder if it is too restrictive, especially for heavier oils.
  • Nummie
Posted September 26, 2007 - 05:55 PM
I've often wondered that too, but then I also thought that the Honda engineers probably thought about it as well and decided on that size for a reason. Generally, they make darn good engines, but nobody is perfect. Just what kind of oil flow is necessary to properly lube the head I wonder ? Maybe the oil pump needs that size tube to develop some back pressure or something ?
  • cleonard
Posted September 27, 2007 - 09:33 AM
It is a common mod to drill out the center of the bolts to allow for a little more oil. I have also seen complete replacements for the oil tube using larger hoses.
  • crmc33
Posted September 28, 2007 - 03:23 AM
The oil tube should flow enough to maintain the oil flow thruough the cam (the cam just rleies on oil flow rather that any sort of high pressure).
Tho Ive fitted a braided HEL hose on my engine for extra reassurance!!
  • scalejockey
Posted September 28, 2007 - 04:48 AM
The pump and flow system are matched. If you mess with the flow in one area the other area(s) will have less flow or presure unless the pump is increased in size or so the "factory" says..,but then again i'm sure the pumps are designed for future wear of the motor and can handle some mods but nothing too extream. Like on the older gsxr susuki's they were oil cooled with jets of oil hitting the bottom of the pistons if ya messed with cam flow you were asking for trouble.
  • martinfan30
Posted September 28, 2007 - 06:52 AM
i agree. i dont think i'll be doing any lubrication sys. mods except for an oil cooler.
Honda XR650L 2017
  • 0 reviews
  • Hot  29 replies
Honda XR650L 2016
  • 0 reviews
  • 22 replies
