XRL Wing Removal?
40 replies to this topic
  • 650_shark
Posted September 26, 2007 - 06:59 AM
#21
Question...has anyone killed an XRL from overheating it? Note: operating conditions are it had the correct oil and amount of oil in it.
If not, then call me what you will, ahhh just ride your pig and don't worry about it.
  • Denn10
Posted September 26, 2007 - 07:43 AM
#22
i havent seen any this year about Ls blowing up cuz of high oil temps yet.
  • Suds
Posted September 26, 2007 - 11:01 AM
#23
I saw it coming. Coming from far away I say. It started with a dim little light in the distance. But now, now....it is....
.....an oil thread.:thumbsup:
Yup, thought the same thing myself. My question wasn't so much about cooling/oil. I was more worried about the stock tank being secure enough with the wings off.
With only the one bolt and the two hooks underneath, the tank feels a little loose/wobbly with the wings off. I was wondering if anyone else ran the stock tank with the wings off, and did they feel it was secure enough? Or, was there any way to tie it in to the holes that are there for the wings?
Thanks for any help...
Suds
  • martinfan30
Posted September 26, 2007 - 12:19 PM
#24
Suds
i noticed the tank thing too when i pulled mine off. i havent done ANYTHING for it and no issues in 2 yrs.
  • cleonard
Posted September 26, 2007 - 02:48 PM
#25
Well, it appears that I tried to kill my XR600 in this manner. I was only partially successful though. Let me elaborate.
I have had two issues that I feel were directly attributable to heat. First I had to replace 2 valve seats. The bike didn't strand me though. What happens is when the aluminum gets too hot it can permanently expand. The seats are a press fit and fail when they are no longer held by the aluminum head. The second issue is with the crankcases. The crank bearing is no longer a press fit. Do some searches and you will find me asking about it in Feb 2006 or so. At that time I was told "don't worry about it" so I just put it back together. It has been running since then with no major problems. I have always worried about it. Over the last year and a half I came to the conclusion that this was caused by overheating. Same process as the valve seats.
If these aircooled bike engines are anything like aircooled airplane engines the actual head temps are a lot higher than the oil temps that you guys are seeing. We are talking as high as 400 or even 450+.
  • 650_shark
Posted September 26, 2007 - 04:21 PM
#26
Crazy...reinforcing the fact that XRs are indestructible. At my work I occasionally come across stuff like that with random industrial components (motors, pumps, etc) I usually coordinate the repair of such items so at times I will have conversations with manufactures and they are like "well, you should replace that but if it still running I would leave it alone".
  • wheelnut46
Posted September 26, 2007 - 04:22 PM
#27
That makes sense. I'm sure the fire side of a frying pan is hotter than the oil inside it.
Air cooled engines have been used for a long time in some pretty harsh environments all over the world (VW, Kubel - pre/post WWII Germany) thanks to their simplicity, reliability and overall low cost/less parts.
  • martinfan30
Posted September 26, 2007 - 08:27 PM
#28
cleonard you are right. several weeks ago when i was doing the nitrogen tests(eventually unimpressed with nitrogen), i used my I.R. temp gun after a good hiway ride on the cyl. head... it read 440-460 depending on where i pointed. the higher being close to the exhaust side of the head. the actual head pipe at the head was well over 500.
  • Motosprtman
Posted September 27, 2007 - 05:08 AM
#29
The XL600R had no wings and ran really hot stock, and it never ever to my knowledge had anyoverheating problems, at least mine did'nt.
  • heavyhitter
Posted September 27, 2007 - 06:23 AM
#30
For the most part heat (unless VERY VERY extreme) is a slow killer. Heat will kill you engine even at safe temps. the same with electronics. Most times we will never see these differences.
Example:
take a microchip and subject it to a constant 250 degrees 24-7 , say it lasts 35 years.
ok now take that same microchip and subject it to a constant 200 degrees 24-7 now it lasts 32 years.
This is just an example. The more heat you have the more wear it will make on you engine, it is a killer over time and unless an extreme event you will not see the difference.
Now heat can and will destroy you oil much faster. Oil is cheap, change it often and save some $$ and dont buy a motorcycle specific oil.
  • martinfan30
Posted September 27, 2007 - 06:53 AM
#31
i think you have your temps backwards.
  • riding4life162
Posted April 14, 2008 - 02:04 PM
#32
OK I know this is an old thread but you guys still think its safe to take the shrouds off for good?
  • martinfan30
Posted April 14, 2008 - 02:28 PM
#33
I had no problems. If you think about it, the oversize plastic tanks eliminate use of the wings.
  • elrontx
Posted April 14, 2008 - 03:19 PM
#34
I have no wings, broke one clean off during a harescramble. No heat problems....I also drilled about 2 dozen holes in the front fender(rear part) to let air flow thru. I also run Rotella 15w-50.
not to hijack the thread but how did you do in the harescramble? i know new england is some tehnical riding!
  • Kenzo
Posted April 14, 2008 - 03:24 PM
#35
.....an oil thread.:confused:
...naaaw...it's a temp thread :thumbsup:
...i just put 5psi air in my forks and it runs 20 degrees cooler :ride:
:thumbsup:
  • XR650L_Dave
Posted April 15, 2008 - 07:39 AM
#36
As long as you've rejetted.
I just use the black inner part on mine.
Dave
  • Motosprtman
Posted April 15, 2008 - 10:36 AM
#37
I use an acerbis XR400 front fender = shorter in the back than stock to let a bit more air in and looks better then the big mutha flappa fender that comes stock.
  • BeeDub
Posted April 15, 2008 - 11:43 AM
#38
Hey, can anyone tell me which is better, D606 or Michelin Desert?
:thumbsup:
  • XR650L_Dave
Posted April 15, 2008 - 12:15 PM
#39
...i just put 5psi air in my forks and it runs 20 degrees cooler :confused:
:thumbsup:
If that 5psi changes the attitude of the bike enough, that's entirely plausible with the stock XRL fender!
Dave
  • Rockjockey
Posted April 15, 2008 - 12:17 PM
#40
The 606 as long as you add 5 psi to the forks and use the purple power band with it.
Honda XR650L 2016
  • 0 reviews
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • 22 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  29 replies
