XRL Wing Removal?
40 replies to this topic
  • Suds
Posted September 24, 2007 - 07:40 PM
I've searched and read some posts on removing the wings/shrouds from the 650L. Most think it doesn't affect cooling that much, so I was thinking of removing them. Definitely like the look better with them off.
My question: When I've had them off for maintenance, the stock tank doesn't seem to be supported very well like it is with them on. I was wondering if this is ok, and are there any mods/aftermarket parts to tie the tank into the frame using the existing holes for the wings?
Thanks,
Suds
  • AtomicGeo
Posted September 24, 2007 - 08:05 PM
Thanks,
Suds
The wings are to help cool the engine. One test may be to use a oil temperature dipstick to see what the temperature difference is w/ and w/o the wings, especially at sustained highway speeds of 70 mph for example.... Personally I took mine off after I went the the aftermarket large capacity Clarke 4.7 gal tank (wings have to come off fot this tank option). I did not do this test, but I am curious to see of the oil temp goes up w/o the wings.
  • Suds
Posted September 24, 2007 - 08:24 PM
From what I've read in other posts, the temp does go up some, but not enough to worry about, except during long highway runs.
I'm more worried abut the tank being supported properly. Seems kid of loose with them off.
Thanks,
Suds
  • Denn10
Posted September 24, 2007 - 09:04 PM
several are running with shrouds off without any tank problems. Martin did a test i think with about 25 degree differences so as long as your not dead summer 100 degrees you should be fine without shrouds. Most tanks are only 2 bolts and a strap rear so dont think you need to be worried about that.
  • AtomicGeo
Posted September 24, 2007 - 09:45 PM
Thanks,
Suds
The Clarke 4.7 gal tank uses an extra support brace that uses the thread mounts that the wings previously used. It is rock solid.
  • Bibleman
Posted September 25, 2007 - 04:15 AM
I did several tests (under strict laboratory conditions:ride: ) and there is no doubt the temp rises faster and higher without the shrouds. The Honda engineers put them on for a reason. I'm not saying you will ruin the bike without them but you must balance it out. Off highway, I saw an average of about 12 - 15 degrees higher and on the highway 25-30 degrees higher:prof: Right now, this is the only thing holding me back from a larger aftermarket tank.
  • AC-DC
Posted September 25, 2007 - 04:27 AM
I wonder if trimming the front fender would help make a difference on the temp?
  • martinfan30
Posted September 25, 2007 - 06:59 AM
it will. it does run a little warmer now w/o wings, but ive had no prob. with tank or overheating. even in 95 deg. temps and wolfman bags loaded up and more piled on top of that.
  • 650_shark
Posted September 25, 2007 - 08:58 AM
I have no wings, broke one clean off during a harescramble. No heat problems....I also drilled about 2 dozen holes in the front fender(rear part) to let air flow thru. I also run Rotella 15w-50.
  • martinfan30
Posted September 25, 2007 - 09:20 AM
good oil is a MUST. an oil cooler will probably get you even cooler than a stock bike.
  • Motosprtman
Posted September 25, 2007 - 10:35 AM
In the summertime without the wings I was running an average of 225-250 (80 degree plus days) with wings back on and running castrol 20-50W I run about 200 ish, with wings on and in the 60's it ran AT 150-180! during a 10 mile ride.
  • AtomicGeo
Posted September 25, 2007 - 11:00 AM
Ok, this answers one question, but the breakdown viscosity of oil should be at much higher temps...what would be the temp at surfaces where metal parts move and causing potential engine seize-ups?
  • Denn10
Posted September 25, 2007 - 12:11 PM
RODRIGEO prolly 300 and up are in that danger zone, since we are just reading the temp in the frame the oil in the motor is prolly gonna be a few higher. Here in CA desert on some 100+ days i saw 275 so that was my highest and i have stock tank with shrouds and NO oil cooler.
  • heavyhitter
Posted September 25, 2007 - 12:39 PM
A good temp for just about any oil should be 220ish. 250 is fine, I wouldnt like to see my oil at 275 for long. If you are in the 250-300 temps make sure you use a 20w50. A 15w40 HDEO oil will stay in grade longer than a 20w50. 50's can shear down to 40w fast on a bike. Most oils have a flash point of @ 380-430ish higher for syntetics. Just change your oil often. I recommend RotellaT for $9 you can change your oil 2x. I have seen excellent OA's on this oil.
  • martinfan30
Posted September 25, 2007 - 12:54 PM
i like honda's 20-50 when its hot or i load it up.
  • wheelnut46
Posted September 25, 2007 - 03:13 PM
<< Switched to a UFO XR400 fender and cut some slots in the back part to help with air flow.
No scientific data to justify but common sense says it's a winner.
  • Denn10
Posted September 25, 2007 - 03:16 PM
I always use 20/50 in mine year round per XRs only, and 1000 mile changes since its not ridden alot, i cant help getting to 275 on a day when its 110 so ill just have to get a 400 cooler before next summer.
  • martinfan30
Posted September 25, 2007 - 08:35 PM
which brand you use? synth or dynosaur ?
  • husky123
Posted September 26, 2007 - 05:39 AM
I saw it coming. Coming from far away I say. It started with a dim little light in the distance. But now, now....it is....
.....an oil thread.:thumbsup:
  • martinfan30
Posted September 26, 2007 - 06:33 AM
isnt it amazing how that oil crap always sneaks up on us!
  • 3 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 9 replies
  • 22 replies
  • 17 replies
