2007 WR450 Wire Harness
7 replies to this topic
  • Sycamore
Posted September 24, 2007 - 09:47 AM
Does anyone know off hand if the wiring harness routes over top of the carb? I took this thing apart over a month ago and forget how it routes. I sure hope it doesn't as it would make changing a needle a bit of a chore:mad:
Thanks.
  • SJMC_DON
Posted September 24, 2007 - 10:43 AM
Thanks.
The shop manual has detailed routing diagrams for all hoses, wiring, etc... I only had mine apart for a few hours and I had to reference them before putting it all back together :thumbsup:
  • face_plant
Posted September 24, 2007 - 11:50 AM
under the tank and between the spars in the frame
  • Sycamore
Posted September 24, 2007 - 01:06 PM
I didn't see a "from the top down" view of it. I'll look again but does it go directly over top of the carb where the needle cover is?
  • Sycamore
Posted September 24, 2007 - 06:35 PM
But is it DIRECTLY over the carb needle cover (top of the carb) or is it off to the side of the carb?
  • Alternative
Posted September 24, 2007 - 09:28 PM
Does it matter? As long as all the wires are getting from A to B without being stretched, crushed or likely to be snagged on anything you can route them however you want. If it's easier for you to route them off to the side, do it.
  • Sycamore
Posted September 25, 2007 - 07:09 AM
I did found the top down picture in the book just a page away from the one I was looking at. Had to use a magnifying glass to read it..I'm getting old!
Interesting no one knew this though?
  • RickSanson
Posted September 25, 2007 - 05:30 PM
Yes, it does right right over the card slide cover between the top engine mounts.
