Sleeving a bearing in the front hub...
7 replies to this topic
  • MOmilkman
Posted March 18, 2002 - 08:27 AM
Has anyone ever put a thin metal sleeve on a bearing to take the play out of it?
When I got my 99 new, I remember the first time I replaced the bearings in the front hub the left side took little or no effort to knock the bearing out. The next time I replaced them it took even less effort. (it almost fell out on its own) I can turn the inner race of the bearing with my finger and see the outer race turning slowly in the hub. So I know for a fact it is a problem with the hub and not the bearing.
So my front hub is pretty much shot and I am looking at $170 to replace it with a stock hub which I dont want to do. Is there anything I can do to make a sleeve for the bearing? It would have to be a wafer thin piece of metal.
Seems like to me this was a fatory defect. But I imagine it has too many miles on it to even consider warrating the hub.
Do you guys have any suggestions on what I could do?
  • Jon_Escombe
Posted March 18, 2002 - 10:55 PM
Had a similar problem with a very old mx bike, would always get grief at scrutineering as they thought the bearing had play..
Wrapping aluminium tape around the bearing worked fine as a bodge. The proper solution would be to look up a bearing with the same ID and a slightly larger OD, then get the hub machined to suit..
  • lewichris
Posted March 18, 2002 - 12:04 PM
anyone ever tried a little locktite
  • wrsm
Posted March 18, 2002 - 12:21 PM
I have used Araldite two part epoxy in the past. Works really well. Refit the axle to the hub to make sure alignment is OK.
  • Guy
Posted March 18, 2002 - 12:24 PM
Kev, you bodger you
:) I'm shocked LOL! :D
  • MOmilkman
Posted March 19, 2002 - 03:48 AM
Thanks guys for the ideas! :D
I espically like the idea of machining the hub out and going one size bigger on the O.D.
Yamaha, just try to get my money!!!! :) :D :D
  • wrsm
Posted March 19, 2002 - 11:28 AM
I would just like to point out to the group (especially Guy :D ) and any other UK riders (especially any future buyer) that my current bike does not have a bearing fixed in place by araldite. :)
Anyway, even if it did, it would be a good fix to the problem!!
"Honest" Kev
  • Guy
Posted March 19, 2002 - 01:27 PM
:) Hmmmnnn.....Never raced or rallied careful owner...well it must have had one careful owner at some point! LOL :D :D
