Newbieee Question
4 replies to this topic
  • CuLayTur
Posted March 18, 2002 - 07:40 AM
I would like to introduce myself. I purchased a used 1998 WR 400 here in Colorado Springs back in January and man is this bike the bomb. I used to ride a XT 225 to learn the basic and needed a bike with more power and a suspension. I found this site when I was doing research on types of bike and have been lurking for a while, reading everything I can about this bike.
Now I have a question I hope someone can answer. The last time I have ridden the bike, I noticed that I was leaking fork oil from under the seal. It wasn't pouring out, but enough to leave a little puddle. It seem to get a little dirt under the seal, which I promply cleaned up with a thin feeler guage. I would like to add a few CC's of Fork Oil back to the shock to make up for the little that was lost. Can I do this without completely disassembling the forks? An How? Do I just bleed any air from the fork with the little screw, remove the cap bolt and add the little oil that I need. Help..
Thanks for any help.
Curt Allen
  • Scott_in_KC
Posted March 18, 2002 - 07:54 AM
My first suggestion is ofcourse going to be...pull the forks off and get them serviced! It's not THAT much for seals & service. The problem is only going to get worse.
If you're attempting to add oil I suppose you could do it through the bleeder hole, but may not be able to check the level. Put the bike on a stand, front wheel raised!! Remove the top cap of the fork with a spanner wrench then do the oil that way. Check the manual for oil height recommendations. NOTE: I have not been in these particular forks yet, just going on basic knowledge of forks.
Get them serviced asap though. :)
  • SealClubber
Posted March 18, 2002 - 05:30 PM
John Olds at Rocky Mountain Cycle Plaza just did my forks. He comes highly recommended around here apparently. Cost me $200 to have the forks and shocks raised back to stock length and revalved for my weight.
There is also a suspension shop in Engelwood that my Denver friends say is great but I can't find their info. Sorry.
Let me know if you ever want to go riding.
Dan
[ March 18, 2002: Message edited by: Dan Lawrence ]
  • Tom_Rowlee
Posted March 19, 2002 - 04:51 PM
Just get new seals and cleaned . things can get pretty gumed up in there . It will handle better after a good cleaning and fresh oil .
  • CuLayTur
Posted March 20, 2002 - 09:16 PM
Thanks for the response guys. I'll be giving John Olds a call in a couple of weeks then to get the front forks a good clean and tune.
Dan, I usually ride the Divide trail system off Trout Creek road. I'll shoot you an e-mail once the trails start to dry up.
Curt
