08 450 levers
13 replies to this topic
  • todds924
Posted September 22, 2007 - 03:43 PM
Does anybody know if ASV or Sunline has put out pivoting levers for the 08? I went to switch mine off my 06 and the brake is different.
  • Chilio
Posted September 22, 2007 - 05:09 PM
ASV makes them, The clutch is the same as other years but I think the brake is like the Honda.
I have them on my 08, I also got the kit that moves the hot start to the throttle side. ASV also makes a nice brake cover now.
Posted September 22, 2007 - 06:31 PM
ASV lists the late YZF and the CRF as the same (BLH01). They do list a special lever for the '07 YZ250F (BLH13), and as Yamaha changed the caliper on the 450 this year, that may be the one that's required.
Chilio, do you have the ASV part number?
  • Chilio
Posted September 22, 2007 - 06:47 PM
I'll try to find my order.
  • todds924
Posted September 22, 2007 - 07:12 PM
I believe you are correct, The 08 master cylider looks the same as the 250-07.I have another question that maybe you can help with, Are you familiar with the works connection radiator cages? You know the ones that enclose the radiator with the two bars on either side and attatch to endplates? I have them on my 06 and they have saved me at least a few sets of radiators. Anyway, I am having trouble finding out if they will work on the 08. Thanks for your time.
Posted September 22, 2007 - 07:35 PM
I think WC is going to be your only conclusive source of that info for now, unless you pull them off your old bike and try them. Let us know if you do that. :thumbsup:
  • Camrose Cycle
Posted September 24, 2007 - 10:17 AM
Ya i used my ASV unbreakable levers from my 07' 250f on my new 08' 450f, fit perfect.
  • Chilio
Posted September 24, 2007 - 11:45 AM
ASV Inventions 877-278-7000
  • todds924
Posted September 24, 2007 - 01:16 PM
Thanks for the info!!!!:thumbsup:
  • Chilio
Posted September 24, 2007 - 04:11 PM
Found my order:
CMF33-k f-3 series Pro model clutch lever w/quick adjust- black
BHF313-k f-3 series front brake lever: yamaha yz 250 07
RCH05-k totator clamp, brake, universal w/ integraded hot start
FBDC01 front brake dust cover
F-3 Series, Black
I can't give prices because I have a sponsorship with ASV
Posted September 24, 2007 - 07:26 PM
Good. Then it is the same as for the '07 YZ250F. Thanks for verifying.
  • Solo
Posted September 25, 2007 - 09:48 AM
[...] ASV also makes a nice brake cover now.
Is the pivot bolt changed in any way to facilitate the mounting of the dust cover? I'm going to order one up to add it to mine. I got the levers before they had the dust cover.
Posted September 25, 2007 - 02:28 PM
I've just always used the stock one on my ASV's.:thumbsup:
  • Chilio
Posted September 26, 2007 - 08:57 AM
The cover comes with a new bolt, its a little longer than the stock one.
  • 0 replies
  • Hot  36 replies
  • Hot  47 replies
  • Hot  50 replies
