Header question
8 replies to this topic
  • Solo
Posted September 21, 2007 - 09:49 PM
What year did Yamaha fix the issue with the header pipe & the oil filter? Will that years head pipe fit on my 2000 WR 400?
Those of you who've not owned older WRs may not be aware but the head pipe is in the way of the oil filter. You have to loosen up the exhaust every time you do an oil filter change.
  • redswr
Posted September 21, 2007 - 10:52 PM
i havn't had a problem with the one on my 99
  • clark4131
Posted September 22, 2007 - 05:25 AM
The only time I've heard of a problem with clearance is when using the Dr. D. header. The only generation of WR I've not worked on is a 426, and I've never had an issue with the others. Interesting dilemma, hmmmm :thumbsup:...SC
  • pjriss
Posted September 22, 2007 - 07:12 AM
No issue with my 02 426 with FMF Powerbomb SX header.
  • Birdy426
Posted September 22, 2007 - 07:44 AM
No issue with my '01 with a stock header. There's no reason it shouldn't fit on a 400...
  • Solo
Posted September 22, 2007 - 09:37 AM
Your sig states you have an aftermarket header. Doesn't apply to my question but thanks.
If you do a quick Google search you can see it was clearly an issue on at least the 2000 WR400.
Again an aftermarket header so it doesn't apply. And again, thanks for the input.
And that would be the answer I'm looking for. :thumbsup: :thumbsup:
  • fadingfastsd
Posted September 22, 2007 - 09:46 AM
I have a 99 WR400 with the stock header, and I have the same problem with the header/oil filter interference. I think it affects 98-2000 or so.
I'm going to look into an aftermarket header, as the stock one is such a pain in the ass.
  • Birdy426
Posted September 22, 2007 - 10:35 PM
Always happy to help.
  • Alternative
Posted September 23, 2007 - 12:30 AM
Yeah, they fixed it on the 426, 400s are the ones with the problem. An 01-02 426 header will directly fit the older 400s. A lot of people did this to solve the problem.
