Stant #'s for Radiator Cap & T-stat
11 replies to this topic
  • 415ZR1
Posted September 21, 2007 - 06:05 PM
Anyone have the Stant, Napa or any common part # for the 1.6 XR650R rad cap?
Same question, t-stat?
Don't know why this data is so top secret. A forum search turned up very little info. Same with google.
The Kaw KX500 1.8 cap part # is 49085-1059, about $25.
  • 415ZR1
Posted September 21, 2007 - 06:47 PM
Hit the jackpot finally, well maybe. To answer my own question, at least for the rad cap, the Stant website only shows two caps for the small metric rad necks, one of which has the 22-24 lbs shown on XR's Only and SRC websites.
http://www.xrsonly.c...T-X650R-CAP.jpg
http://www.stant.com...location_id=179
Measuring my BRP rad neck and rad cap, looks like either the Stant 10361 0r 10362 will fit. So, until I can get the caps in my hands, these two Stant numbers look promising and may give the BRP rider a couple of options:
Honda OEM 1.1
Stant 10361 (19-21 pounds) 1.4 $30 partsamerica.com
Stant 10362 (22-24 pounds) 1.6 $30 partsamerica.com
Kawasaki KX500 49085-1059 1.8 $25 ronayers.com
Caveat...as far as I know, only the Honda and Kawasaki caps will fit. Haven't tried the Stants, but both should fit.
Now to figure out the t-stat question...
  • xr650rdaddy
Posted September 21, 2007 - 07:30 PM
Hey Go On Ebay 20 Bucks To Your Door Pit Posse Is The Seller I Bought One Works Great No More Puking When Your Riding Or I Mean Waiting On You Buds 650r's Rule
  • Descalzo
Posted September 21, 2007 - 08:06 PM
lol, that's funny cause I just bought a t-stat about a week ago. I'd have sworn I had the receipt floating around somewhere...
anyway, can't give you the PN, but the stat for a '90 Suzuki Swift with the 1.3L engine is the one you want. Comes in a 160*, a 180*, & who knows what else version. Drill a 1/8" bypass hole in the flange & drop it in.
  • weskc35k
Posted September 21, 2007 - 08:35 PM
I have removed my thermo and housing and made a y piece for the hoses.
  • 415ZR1
Posted September 21, 2007 - 08:50 PM
That's a start! I even have a Suzuki Sammie in the driveway that uses the same 1.3 motor. Probably have an old Samurai t-stat to do a trial fit...and then source a Stant #.
  • scalejockey
Posted September 22, 2007 - 02:34 PM
I got a t-stat from Napa it's a P\N 115 just drill a 1\8" hole in it. It's a 165 Degree
  • GlobalWarmer
Posted September 22, 2007 - 10:02 PM
Why drill a hole? What's it do?
  • porterdog
Posted September 24, 2007 - 10:11 AM
Allows a big air bubble to burp out before the t-stat opens so you don't overheat your scoot.
  • Phuzzy McPhuzzface
Posted December 29, 2007 - 08:43 PM
Also lets some coolant flow even if the stat gets stuck closed.
  • bosshog
Posted December 30, 2007 - 08:59 AM
Also lets coolant flow so hot coolant from the head will reach the Tstat so it will open when needed(sooner). There could be quite a difference in temps between the cylinder and where the Tstat is located if there is no flow at all.
I took my original Honda Tstat (which was stuck wide open as they all will be) with me to the auto parts store. Find one the same size and temp you want and drill the hole as stated.
  • ODSC1
Posted January 04, 2008 - 09:19 PM
I believe the Carquest part number for the thermostat is 30978.
Brian
