Help with 06 yz 450f
2 replies to this topic
  • iowamarinedad
Posted September 20, 2007 - 06:47 PM
Thinking about trying a heavier flywheel 9oz-I ride mostly motocross.
Any thoughts if i should or shouldn't?
How did the heavier flywheel effect your 450?
I ride mostly hard baked tracks
Thanks for any input
  • Ga450owner
Posted September 21, 2007 - 06:29 AM
It all depends what you are trying to accomplish...and your skill level.
if you have way too much wheelspin on those hrd baked tracks then yes a flywheel weight will help. More torque to the rear wheel.
But you need to investigate the weight you are considering. I would call DRD for some advice or maybe someone who has gone through the exercise on different flywheel weights can assist here. 9oz seems too heavy to me on a stock motor for MX only
Posted September 21, 2007 - 07:52 AM
Read this:
http://www.thumperta...ad.php?t=554240
  • Hot  36 replies
  • Hot  38 replies
  • 5 replies
  • Hot  30 replies
