valve cover breather tube sucking in dirt???
24 replies to this topic
  • Yamaha4lyfe
Posted September 19, 2007 - 07:11 PM
pulled my valve cover and cams out a few days back. to re shim it. what do you know there is SAND IN MY FREAKING engine!@!@!! right in that hole where the breather tube attaches to. what the hell? i stuck my finger in there and pulled a crap load of dirt out. i don't understand?
  • rooster wrooster
Posted September 20, 2007 - 03:49 AM
I pulled mine off my '06 a few months ago and found the same thing. Not a crap load but more like a sprinkling. I rerouted the the hose into the airbox, which is pretty easy to do, but haven't pulled the cover yet to see if actually helps.
  • Wiz636
Posted September 20, 2007 - 06:06 AM
Same thing here. There is a thread here all about this and about rerouting into the airbox. I did it the other day and zip tied a foam filter onto the end also.
Posted September 20, 2007 - 06:43 AM
http://www.thumperta...ad.php?t=447989
Scroll down to Engine, and look for breather tube re-route
  • Yamaha4lyfe
Posted September 20, 2007 - 09:49 AM
thanks grey
  • casperkc
Posted September 20, 2007 - 02:59 PM
That stupid idea they had cost my insurance company $4000.00 to rebuild my motor. The only thing salvagable was the head and the gears. EVERYTHING else was replaced. I stalled in a small pond\mud hole on the trail. Slurppppppppppp.
  • tonypitcock79
Posted September 20, 2007 - 04:57 PM
doesn't hot exhaust air going back into the motor kill horsepower???!!!!
Posted September 20, 2007 - 05:07 PM
What hot exhaust air?
  • sherco67
Posted September 20, 2007 - 05:10 PM
after reading all the threads about this, I went to home depot and bought 10 feet of black half inch hose for 5.00 and a 1/2 inch t-fitting and a pcv filter from advance, should have also got a 90 degree fitting because hose liked to kink at top of engine, run original hose along frame (inside) put T in middle drill 1/2 inch hole and run hose in very bottom corner of airbox, and mount breather to subframe, tie wrap to bracket where carb vent hoses run through to keep away from chain, then through linkage with other hoses. I also put 2 small slices on end to keep dirt from plugging hose. all cost total was about 15.00. good luck, john p.s. everything needed is in plumbing section.
  • Ga450owner
Posted September 20, 2007 - 06:17 PM
no different...never start these under water...or even with any chance of the breather tube being in water.....or mud.
Posted September 21, 2007 - 06:29 AM
...or high centered on a sand dune.
  • kpflyingv
Posted September 21, 2007 - 12:40 PM
On day one I rerouted my hose and installed a K&N filter. It breaths in and out easily and guarentees no dirts sucks in. The filter is strapped with wire ti=es behind the frame in the photo. Easy to clean, and no dirt in the engine.
  • spc mike
Posted September 25, 2007 - 09:56 PM
i just clamped on a little blue 3 inch mini filter that i bought at pep boys, and it works great. i also think by filtering this breather tube will extend your oil change intervals because your keeping more dirt out of the engine.:thumbsup:
  • Polyrida400
Posted September 25, 2007 - 10:00 PM
My wr 450 goes to the air box and its never had shit in it.
Definatly re-route the thing as it will suck the crap in for sure...
  • Yamaha4lyfe
Posted September 25, 2007 - 10:10 PM
i re routed it and i am still getting dirt into it... anyway i can get a filter for it? someone said they put a K&N air filter on it? whats the part number or, whats it called ill buy one from Lordco if they sell them
  • sandman3
Posted September 26, 2007 - 03:24 AM
I ran mine straight to the air box and also put a K&N filter on it. I used a small crankcase breather filter for a Harley Davidson, it works great. When I first got the bike I stalled in a huge puddle, not knowing any better I re- started the bike and after a half miniute or so I was on my way, later that day I droped the oil plug and almost fell on the floor, The motor was filled to the top with milky oil.
  • alstar250
Posted September 26, 2007 - 10:46 AM
I want to order that breather filter but does anyone know what size the breather tube is??? I am going to run a fitting on the end then stick the filter on the fitting so I need to know the tube size...thanks
  • mn519
Posted September 26, 2007 - 12:49 PM
...[COLOR="DarkOrange"] cost my insurance company $4000.00 to rebuild my motor.[/COLOR]
How did you get your insurance company to pay for a mechanical issue? What company do you use?:thumbsup:
  • casperkc
Posted September 26, 2007 - 06:11 PM
I wanted theft and fire coverage and all they could offer me was basicly full coverage insurance. It costs me 14 buck a month through State Farm in Michigan. :thumbsup:
Also I didnt start my bike in the puddle, I stalled in the puddle. Piss poor design on Yamahas part. This is the only manufacturer that routes them this way.:thumbsup:
I got my filter from an auto parts store. I think it was an old school valve cover breather (what a coincidence).
  • Wiz636
Posted September 27, 2007 - 12:09 PM
I do the same thing on mine and it works great. For a filter I just went to an auto parts store and bought a filter designed to fit in the air cleaner housing for the crankcase breather of an old Ford I think. It is a plastic housing with the replaceable filter material stuffed in it. The breather tube slips right on the filter and I use a zipty to hold the tube on. It fits nicely into the recess of the frame and I just zipty it in place.
  • On January 15, 2017
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • 0 replies
  • Hot  30 replies
