XR650L rod movement question (+ advice on parts to replace during complete teardown)
9 replies to this topic
  • machman
Posted September 19, 2007 - 07:46 AM
Hey all,
Got my XRL apart and am waiting for hot cam, 10.5:1 piston, and time to put in my new transmission. I'll be splitting the cases this week.
Question is this, before I re-assemble, I'm trying to get a sense of whether or not any of my bearings need replaced.
Mainly I want to know how much side to side movement I should see when I grab the piston end of the rod and move it side to side?
Also, is there anything else I should look for before re-assembling this engine? Any common weaknesses I should know of? Any other parts I should install at this point while I've got the engine 100% torn down?
  • martinfan30
Posted September 19, 2007 - 08:57 AM
Hey all,
there will be some side play, just no up and down. not sure of the spec., do you have a manual?
look into the case and look at the trans. gear surfaces. especially 3rd. they should be smooth with NO pitting. if there is pitting, replace the gears.
let us know the power difference when done. i want to do this to my xrl. what carb you run? any exhaust?
  • machman
Posted September 19, 2007 - 10:46 AM
When I complete this project next month here's what I'll have in my '93 XR650L at 3000'
-2000 transmission
-stock carb with:
shim: .05"
5/32 holes drilled
3 1/8 turns out on air screw
165 main jet
52 pilot jet
-K&N pod filter
-White Bros header
-Supertrapp IDS2 with 12 plates
-Lightly ported/matched head
-101mm 10.5:1 JE piston
-hot cam stage 1
I'm guessing that the stock carb won't be ideal for this setup. I anticipate needing / getting the FCR pumper this winter.
55RWHP here I come!:thumbsup:
  • martinfan30
Posted September 19, 2007 - 10:57 AM
-2000 transmission
-stock carb with:
shim: .05"
5/32 holes drilled
165 main jet
52 pilot jet
-K&N pod filter
-White Bros header
-hot cam stage 1
that looks really good! fire breathin' porker! i use a fcr41 i bought from sudco. love it! killer response. let us know he she runs when done. get er dyno'd too.
  • machman
Posted September 19, 2007 - 07:40 PM
I just checked the specs and it looks like I'm good.
On another note, there was bit of slack in the old piston pin to rod clearance, but it appears that the new pin will tidy a lot of that up. Might explain a bit of the noise I got at idle...
Thanks for the input!
  • martinfan30
Posted September 19, 2007 - 07:43 PM
oh yeah, piston pin play will make a nice upper end noise. just make sure the upper end rod bushing/bearing is in good condition.
  • machman
Posted September 20, 2007 - 08:19 AM
On that note, the tolerance between the new piston pin and old rod is .0001" over the max of it's limit. It is actually at 0.002" instead of the 0.0019" max listed in the manual. The service limit is listed as being WAY more than that...
Do you think I need to spend the extra couple hundred bucks on a new rod? I am going to be seeing somewhere around 50HP, but I don't want to break the bank unnecessarily...:thumbsup:
  • martinfan30
Posted September 20, 2007 - 08:29 AM
thats going to be a judgement call. a tough one. unfortunately those specs are set at a specific number for a reason. also being at around 50hp... man i'd like to see some other opinions.
  • Denn10
how are you measuring the inside of the rod? you are talking outside of piston pin and inside of rod right?
  • machman
Posted September 20, 2007 - 08:32 AM
yup. Engine's apart. Calipers inside small rod hole, calipers outside new rod pin, subtract = .002"
  • 4 replies
Honda XR650L 2016
  • 0 reviews
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • Hot  60 replies
  • Hot  29 replies
