KLX 110 that is hard to shift into gear!!Help!!!
9 replies to this topic
  • 2006rmz450
Posted September 17, 2007 - 05:07 PM
I just put a 4 speed shift drum in my 110 and it is hard to shift into first gear. It also has six heavy duty clutch springs. Any advice would be greatly appreciated.
  • bits 50
Posted September 17, 2007 - 05:57 PM
Did you adjust the clutch?
  • king110
Posted September 17, 2007 - 08:37 PM
Does it shift hard going into all the rest of the gears? They always pull hard with hd clutch springs. Try 3 or 4 instead of all 6. Just stagger the hd and stock ones. Your not only shifting the bike your releasing the clutch plates at the same time. If you go with a manual clutch you shifting will become easy again.
  • 2006rmz450
Posted September 18, 2007 - 04:11 AM
I did adjust the clutch but nothing helped. I was told that I needed all the clutch springs because we are running a 143cc kit, cam, big carb and exhaust. It is very hard to shift into first gear. I pull it up with my hand but after that I can shift with my foot.
  • king110
Posted September 18, 2007 - 08:52 PM
Does the bike lurch or jump when you shift it into gear? Sounds to me like it is just the springs. Every 110 I have ridden with the auto clutch and hd springs shifts hard.
  • 2006rmz450
Posted September 19, 2007 - 03:59 AM
No, it does not lurch or jump it is just hard to shift (extremely hard).
  • bits 50
Posted September 19, 2007 - 03:21 PM
Is it hard to shift with the engine off?
  • 2006rmz450
Posted September 20, 2007 - 04:10 AM
Yes it is hard to shift with the engine off.
  • bits 50
Posted September 20, 2007 - 04:50 PM
At this point I think we can eliminate the clutch as being the problem. Since the problem started after the shift drum was installed I tend to believe that there is a problem with the drum or in the reassembly.
  • 2006rmz450
Posted September 21, 2007 - 04:19 AM
The problem has been solved. It was the stiffer clutch springs. Thanks for all the help.
Scott
Suzuki DR-Z70 2013 by Chris.GVS
Suzuki DR-Z70 2013
  • 0 reviews
Kawasaki KLX110L 2014 by Chris.GVS
  • 0 reviews
KLX 110L Shock for Kids/Youth Riders (pics) by oldmxer63
Dirt Bike   Make / Model Specific   Kawasaki   KLX 110
  • Hot  55 replies
Suzuki DR-Z70 2014 by Chris.GVS
Suzuki DR-Z70 2014
  • 0 reviews
Kawasaki Recalls Off-Road Motorcycles Due to Crash Hazard by Bryan Bosch
  • 2 replies
