How do you check for chain wear
4 replies to this topic
  • srhines67
Posted September 17, 2007 - 12:02 AM
I have a DID ERT2 (non O ring) with 25 hours of trail riding on it. It seems like the links are loose - when flexing the chain side to side by hand - but I can't remember exactly how it was when it was new. How do you determine if a chain is worn out. Oh, I don't like to lube chains either.
  • Dirtbiker05
Posted September 17, 2007 - 01:52 AM
it shouldnt be worn out that quick... unless u dont have the chain at the proper tension and dont use a good lubricant. no lube and too tight or too loose on a 450 isnt easy on the chain and sprockets. :thumbsup:
Posted September 17, 2007 - 06:00 AM
Take a pair of 6" vernier calipers and set it to 5.85". Then push down on the bottom run of chain and measure between the rollers on the tightened top run. If you start with the dimension above, your caliper will sit between two rollers with nine pins between them. The measurement should not exceed 6", by the book (I give up on them at 5.94"). Be sure to measure several different sections.
If you don't have access to a caliper, lay the chain out on the floor and pull it out to it's maximum length. Count out 101 pins and measure the distance between them. New is 62.5", the 2% maximum length is 63.75. Again, I'd discard it at 63.4" (1.5% over length)
  • 642MX
Posted September 17, 2007 - 06:27 PM
2 things..... 1. Non-O ring chains are not great for woods riding. 2. A good lube like Maxima Chain Guard will help them last longer.
If I was you, I'd go buy a new steel sprocket set and an O-ring chain and start over.
Don't forget to buy some chain lube too. :thumbsup:
  • 642MX
Posted September 17, 2007 - 06:29 PM
Interesting. :thumbsup: I've never measured one, but it makes sense.
  • 0 replies
  • Hot  36 replies
  • 10 replies
  • Hot  38 replies
